30th July 2012
Posts: 3,211 Sportster/Buell Model: xlch sportster Sportster/Buell Year: 1969
I just got a 530/106 Tsubaki last month for $33.
30th July 2012
Posts: 4,181 Sportster/Buell Model: XLCH Sportster/Buell Year: 1974 Sportster/Buell Model #2: XLS Sportster/Buell Year #2: 1980
Hey here's what he had in his other thread some of you maybe missing. ck this out
Murphy's Law :vvet:
Reason: I think I fixed it
30th July 2012
Posts: 222 Sportster/Buell Model: Harley Sportster XLCH Sportster/Buell Year: 1974 Sportster/Buell Model #2: Harley Sportster XLH Sportster/Buell Year #2: 1975
How is your swing arm bearings are they wasted to? maybe you where running the chain to tight all the up and down movement on the swing arm maybe caused all the damage.
30th July 2012
Posts: 1,280 Sportster/Buell Model: XLCH Sportster/Buell Year: 1968 Sportster/Buell Model #2: XLH1200 Sportster/Buell Year #2: 1991 Other Motorcycle Model: Chopped Shovel Other Motorcycle Year: 1978
Alignment - I use a straightedge and ensure it is dead on. If I'm not touching front and back of both sprockets, not good enough. Spacers work great, in your configuration, but I'm sure you can handle that part.
Cracks - if a few are showing cracks, you can bet that the remainder are a breath away from the same. Uneven stress is being applied everywhere, with a chain in that condition. A few master links and a chain breaker are gonna lead to busted cases, possibly going down, or if you're "lucky", like me, just a good chain mark up your back, and maybe it'll miss your ear, like it did mine.
A few thou offset, won't hurt anything, as far as alignment is concerned, but if the rear is 1 degree, or even a half, off true, that will add up to one stressed side of the chain. Couple that with running it for a couple of years (how many miles do you pound off in a year?) on a sprocket that was not replaced when the chain was, and you are where you are at today.
I'd say time for full chain and sprockets.
Stupidity and being cheap, I blew a chain, which looked like yours (less the battery acid treatment) and got "lucky". I'd say I'm a little OCD nowadays on alignment and replacing sets, not just chains. Costs a few more bucks, but worth it, IMO.
You could put a second master link in your current chain, and blow another link in a few miles. Risk would be too high for me.
Disclaimer: I'm not the expert on this stuff, be sure to seek further opinion/knowledge.
30th July 2012
Posts: 7,996 Sportster/Buell Model: XLX-61 Sportster/Buell Year: 1983 Other Motorcycle Model: Honda CL350 Other Motorcycle Year: 1969
Is that one of those cheap-o farm equipment chains? Man, I wouldn't ride mine around the block if the chain looked like that, even with the cracked links replaced with master links. Whatever caused those to break may cause more of them to. If it breaks and slings off, terrible things could happen...like destroying the engine/transmission, locking up the rear wheel and throwing you down the road (or worse), flying off and hitting you, etc.
You need a new rear chain. The Diamond Heavy Duty chain is good and relatively cheap.
30th July 2012
Posts: 2,509 Sportster/Buell Model: xlch Sportster/Buell Year: 1977 Other Motorcycle Model: BMW K-1200/GT Other Motorcycle Year: 2004
If you don't replace everything....do not....repeat....do not ride that thing.
31st July 2012
Posts: 9,331 Sportster/Buell Model: XLCH 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 75 motor in Norton frame. Other Motorcycle Model: 42WLA 45, Harton, Narley Other Motorcycle Year: 1942
Throw that chain away before it causes you serious grief. Once a chain gets that bad it is all bad, so no point in patching it with master links. That is the worst condition chain I have ever seen.
And move your battery box over a quarter inch so, or whatever it takes so the chain is not hitting the battery, or the piece of stainless you put in there. That kind of abuse is only going to trash your chain again.
Your rear sprocket is so worn it is starting to hook so I would fit new sprockets too.
31st July 2012
Posts: 583 Sportster/Buell Model: xl 1000 Sportster/Buell Year: 74 Sportster/Buell Model #2: Sportster Sportster/Buell Year #2: 76 Other Motorcycle Model: Panhead Other Motorcycle Year: 56
It's a hardtail. Swing arm bearings are good to go
"we, outlaws on God's property,
Fling out imagination beyond the skies,
Wishing a tangible good from the unknown."
74 Custom Rigid XL,
"stuff"
Some dirty chrome, a little duct tape and lots of rust
One headlight, one tail light, one brake, and lot's of balls!
31st July 2012
Posts: 12,251 Sportster/Buell Model: xlch Sportster/Buell Year: 1960
are you saying battery acid isn't corrosive? try putting some on your eye balls. in a,diluted state,the corrosiveness is what's cleaning the oxidation off the chrome.
31st July 2012
Posts: 544 Sportster/Buell Model: XLCH Sportster/Buell Year: 1969 Other Motorcycle Model: FXE Superglide Other Motorcycle Year: 1976
Hey Sturg when that chain breaks (and it will) there will be a good chance it takes out your sprocket cover or even worst. I have a decent chain I just removed from my 72, if you want it send me a PM with your mailing address.
The Beast of Burden [URL="http://www.youtube.com/watch?v=d4WFOZYO2Xw"]69 XLCH[/URL]
