Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER & BUELL MOTORCYCLE RACING > LSR - Sporster & Buell Motorcycle Land Speed Record
LSR - Sporster & Buell Motorcycle Land Speed Record Discuss Sportster & Buell Motorcycle Land Speed Record events.
0 Lowboy frame conversion
0 C.O.B.B run west
Last Post: skien
Last Post: Bwf347
0 New 2017 H-D Street Rod XG750A
Last Post: Bone
0 Removing oil key from shaft
0 2003 1200 Custom riser
Last Post: ahusain
0 What's your helmet?
Last Post: The Crusher
0 Primary Oil INSANITY!
Last Post: ed_in_az
0 Did I buy the wrong length chain?
Last Post: Yochstein
Old 4th August 2012
outside the box racing
Sportster/Buell Year: 99
Sportster/Buell Year #2: 2000
Other Motorcycle Year: 1991
TGB #8
Old 4th August 2012
apparently they have updated the seven zero seven vendetta to M2010 while i wasn't paying attention!
it is NOT a high end helmet but if it fits your head and your needs (it does mine) you cannot find ANY snell helmet this cheap...
regular price at cycle gear is 139usd, on sale now for 99usd.
i have used this helment for a year (when i wear a FF) and it works, doesn't ride weird and is pretty light. can't get hurt to bad in the back pocket anyway at this price.
Old 4th August 2012
debster's Avatar
debster debster is offline
debster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to alldebster is a name known to all
Donation sent! Good luck, go fast, and be safe!
Never argue with a woman holding a gun.
~Momma of the Sons of Santa MC
RIP MrJimi... miss you.
2000 XLH 883 Hugger
Old 5th August 2012
thank you debster!
you guys have helped me replace the wasted rear tire with a michelin pilot power pure
and the completely worn out front brake pads. all 4 of them. ouch.
thank you so much.
the next target is leathers from A1leathershop and entry fees.
Old 5th August 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
Just put a little jingle in your lime, tequila and salt fund.
Be safe buddy!
[SIZE="2"][/SIZE]Support the forum because the :xlrocks
George
[COLOR="Blue"][B]"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson[/B][/COLOR]
Old 5th August 2012
thank you george - that took some of the sting out of today's cash hemorrhage!
Old 5th August 2012
helmet, rear tire, front brake pads, lighting - $600 weekend. Thank you guys for all your help!
Old 5th August 2012
rottenralph's Avatar
How much do you think you need to make this happen? Do you know? Are there any parts that you need as well?
Old 5th August 2012
i guess it is time to itemize.. let's start with the easy stuff:
$650 X 2 entry fees + first class at each event
$250 X 6 class changes
$350 leathers
$600 backup cylinders
$??? extra crank assembly or complete bottom end - this i need to get to the boys in idaho immediately and just pray they can squeeze another crank job in.
PARTS NEEDED:
I need a crankshaft assembly that i can have prepared and ready to split the cases and swap it out in the few days i have between BUB and WOS. If anyone has one, or better yet, a set of cases with a crank in it, that they want to sell BUT can wait until october to get paid that would make it MUCH more likely that I can make all the passes and get all 8 records.
Michelin Pilot Power Pure front (120 17) and rear (180 17). I just bought a rear but the front is almost ready and i need a backup rear.
that's about it for parts that can be bought or donated. i need to make a salt legal fender that has a water tank integrated, some softail struts and fabricate the mounting bracket for the busa fairing but that is about it.
Old 5th August 2012
i have been bidding on this the last couple weeks and have always been the winner but my bid didn't make reserve.
the guy has reduced the price to $700 but still more than i have in pocket right now.
http://www.ebay.com/itm/2002-Harley-...item4abaa02ef1
