0 New from Utah
Last Post: XLXR
0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Old 5th August 2012
Jimmy_Hoffa's Avatar
Jimmy_Hoffa Jimmy_Hoffa is offline
Jimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to allJimmy_Hoffa is a name known to all
Default Do you park in nuetral?
The manuel says not to shift when the engine isn't running, says it can hurt the tranny. I try to shift to nuetral before shutting down. On accasion I have parked in gear and started it in gear also.
The other day I parked faceing down my driveway and didn't trust the kickstand, so I put it in gear while it wasn't running. Then found nuetral before starting it. I'm gentle with it, I roll it around a little, so I'm not forcing it into gear or anything.
Is that bad for it?
Old 5th August 2012
grizz420's Avatar
grizz420 grizz420 is offline
Sportster/Buell Model: 05 1200R
Other Motorcycle Model: V star classic wife's
grizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the roughgrizz420 is a jewel in the rough
I park mine in gear and shift to nuetral before starting to back it out of the garage.Been doing that since new and no probs in 30K miles.
Only time I park in nuetral ,is if I leave it running.
05 1200R Forcewinder XR air filter, Mikuni HSR 42,Super Trapp 2-1 pipe,TC88a ign., head light visor, chin spoiler, sport front fender, solo seat off 883, 12 and 1/2 inch dual rate Works shocks , dual rate Works fork springs
Old 5th August 2012
beuz's Avatar
beuz beuz is offline
Sportster/Buell Model: SPORTSTER "old boy"
Sportster/Buell Model #2: SPORTSTER CR (sold)
Sportster/Buell Year #2: 1998
Other Motorcycle Model: Suzuki GSF 650 Bandit
beuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond reputebeuz has a reputation beyond repute
Always on neutral.
You live more in 5 minutes flat out on a bike like this than most people do in a lifetime...
Burt Munro.
Old 5th August 2012
Gcram399's Avatar
Gcram399 Gcram399 is offline
99.9% of the time I put mine in nuetral before I shut it off. That way, when I want to go for a ride, I can start the bike before I get on and leave it warm up while I'm putting on my gear. It's just easier that way for me.
And just for the record, I always look for the nuetral light before I hit the starter button.
[SIZE="2"][/SIZE]Support the forum because the :xlrocks
George
[COLOR="Blue"][B]"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson[/B][/COLOR]
Old 5th August 2012
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: FXDL
Other Motorcycle Year: 2014
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Almost Always in neutral. Though sometimes if forced to park on a slight grade I will leave it in first to prevent any rolling.
Old 5th August 2012
JohnK's Avatar
JohnK JohnK is offline
Sportster/Buell Model: Dearly Departed XL1200C
Other Motorcycle Year: 2000
JohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant futureJohnK has a brilliant future
Is that bad for it?
That's the first time I've heard that! But I don't have a manual and it wouldn't surprise me at all that HD would note that. Kinda funny they would say that, yet shifting, occasional misshifts, banging through gears etc, behind 50 or more ft/lbs of torque is not a problem? Personally I try to put in neutral before I shut down, mostly because I occasionally forget to check for the green N when I fire it up, and since it doesn't have a neutral safety switch... I end up looking like the idiot I am
John from Windsor Ontario
'00 FXDL
Old 5th August 2012
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Depends on the grade for me. I thought it was pretty darn funny the first time I saw someone try to start their bike in gear. I also remember the first time I tried it. The crowd loved it.
"Only Fools Celebrate A Fool"
Old 5th August 2012
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
99.9% of the time I put mine in neutral before I shut it off.
Unless I'm on a grade.
Also, I ALWAYS shut my scoots off with the kill switch so in an emergency I'll shut it off that way without having to think about it.
Old 5th August 2012
rabidchimp rabidchimp is offline
Sportster/Buell Year: 97
rabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enoughrabidchimp will become famous soon enough
I always park the bike in neutral. My idiot light always blew out when I replaced it, so its been "out" since 06 or so. I just always start the thing with the clutch lever pulled in, just in case. I always kick it into neutral coming to a stop too, and only put it in gear when I'm ready to roll.
-Aaron
Stairman for President 2012, 2016, 2020 etc.
Old 5th August 2012
threat357's Avatar
threat357 threat357 is offline
Sportster/Buell Model #2: 1200 CHOP PROJECT
Sportster/Buell Year #2: 1997
Other Motorcycle Model: 1200 CHOP PROJECT #2
Other Motorcycle Year: 1992
threat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to allthreat357 is a name known to all
I don't know why HD would say that, but I don't see what the problem would be, as long as you're holding in the clutch when doing so. I mean, odds are you're just having to drop from 1st to N.
I think the reason they tell you to park in neutral is to help minimize incidents of people starting their bikes in gear and hurting themselves or the bikes by dropping 'em. Saying it will hurt your transmission just gives people incentive to make the effort to find neutral, even if it's not really true.
I park my bike In gear about half the time, and have been doing so for the whole 13 years I've been riding with no problems.
Sent from my DROIDX using Tapatalk 2
