Last Post: sltm1
0 What's your helmet?
Last Post: Zoharo
Last Post: Wharfcreek
0 04 sportster custom 883, turn signal module (TSM)
0 Silverado Power lock issues
0 C.O.B.B run west
0 no rear brake light
0 New England 2018
Last Post: tvon
Last Post: groovemeisterus
Old 5th August 2012
MacSporty02's Avatar
MacSporty02 MacSporty02 is offline
Other Motorcycle Model: FXDLI
Other Motorcycle Year: 2008
MacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant futureMacSporty02 has a brilliant future
Since Oregon is pretty flat, I always leave it in neutral whenever I park. If I left it in gear, I know I would forget to pop it back in neutral before I turned the key, and I never turn the fuel off either. In an earlier thread I mentioned a reason why I leave the fuel on; years ago I had a honda VT500 Ascot and I would forget to turn the fuel on and I could go about a mile before it sputtered, not so with the Sporty, as soon as I would fire it up and let it warm a bit, and ride away, It would go about ten feet n die!! But, no, I leave the Sporty in neutral with gas on.
Old 5th August 2012
er.....I meant Portland, well, in SE Portland it is pretty flat in some places, i.e., my driveway!!
Old 5th August 2012
madnss's Avatar
madnss madnss is offline
Sportster/Buell Model: 883 Xl
I park in gear almost every time
Old 5th August 2012
JasonSarratt's Avatar
JasonSarratt JasonSarratt is offline
Sportster/Buell Model: Turbo XL Sidecar
JasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud ofJasonSarratt has much to be proud of
Never had issue with Sportster but I got in the habit of parking in gear from big twins. Shut the motor down, once it stops I let the clutch out and let it roll till compression stops it then I put it on the stand... On my big twins from years passed if you didn't do this you'd end up eventually shearing the stand stop and it would hit the ground in good time...so I still do the same on Sportster
Sent from my LG-P999 using Tapatalk 2
Old 5th August 2012
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
WHY? Only unless the sporty is parked on a grade..then it's always in neutral cause of the locking kickstand on H-D models..
RTFS
Ride That F'N Sportster!!
Old 5th August 2012
madnss's Avatar
I second that statement
Old 5th August 2012
egadd's Avatar
egadd egadd is offline
Location: SW PA, between Pittsburgh PA and Morgantown WV
Sportster/Buell Model: 883 Hugger/1200 conv
Other Motorcycle Model: H-D Nightrod
Other Motorcycle Year: 2007
egadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really niceegadd is just really nice
dumbest thing ever... do you park your car in N? unless it is parked running it is parked in gear
Old 5th August 2012
Like I said, never had a issue with xl's, BUT have owned plenty of others that sheared safety stops or broke stand pins. If its parked on a grade or flat ground alike, if someone bumps it or the grade stresses the safety or pin they break and the stand will not hold it up its just a personal observation and choice... Buell had these issues to
Old 5th August 2012
Like I said, never had a issue with xl's, BUT have owned plenty of others that sheared safety stops or broke stand pins. If its parked on a grade or flat ground alike, if someone bumps it or the grade stresses the safety or pin they break and the stand will not hold it up its just a personal observation and choice... Buell had these issues to.
Just cause the safety is there doesn't mean it can't fail... Also its designed to keep the stand down as you rest it down on it...its not a parking brake
Old 5th August 2012
norseXL's Avatar
norseXL norseXL is offline
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
Ain´t no locking kick-stand on 4-speeds Evos, still I allways park in neutral exept for on ferrys or pointing down hill.
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
