0 1968 XLCH Oil Leak
0 Sportster or Street Bob
Last Post: Bone
0 67 Front Axle Reinstall/Tighten procedure
Last Post: ss396
0 no rear brake light
0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: 60weight
0 New member in MD
Last Post: xraytoken
0 Help me with gas cap...
0 Burly Brand x Billet Proof
Last Post: BILLETPROOF
0 Cad Plating
Last Post: conv90
0 Running CVP velocity needle. shims?
Last Post: CVPerformance
Old 7th August 2012
iron227 iron227 is offline
Sportster/Buell Model: xlh 1000 sportster
Sportster/Buell Year: 1976
iron227 will become famous soon enoughiron227 will become famous soon enoughiron227 will become famous soon enoughiron227 will become famous soon enoughiron227 will become famous soon enoughiron227 will become famous soon enoughiron227 will become famous soon enoughiron227 will become famous soon enough
Default Help with no spark...
I have an issue of no spark with my 76xlh... Prev owner has dyna s ignition on bike and I have put new coil, Plugs, plug wires, and all new main wire harness including hand controls... I'm not sure what can go wrong with the dyna s as it looks pretty basic.... Checked wires from coil back and they are not pinched or frayed any where... The Dyna s looks good as well as I opened up and the internals and move as I think they should??? Don't know what to check next??? Im hoping it's not needing new ignition...that's my guess. Wanting to get the beast up and running so all help and suggestions are welcomed and appreciated.
Old 7th August 2012
I would do voltage drop tests on each circuit. Start with the wire from the batt+ to the 30 amp breaker - check voltage at the batt+ and on each side of the breaker. Then do the same for each wire from the breaker to the ignition key switch, etc. See if at any place the voltage drop is too much.
Old 7th August 2012
gungatim's Avatar
gungatim gungatim is offline
Sportster/Buell Year: 79
Other Motorcycle Model: Yamaha TX500
Other Motorcycle Year: 74
gungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura aboutgungatim has a spectacular aura about
I would check the easy things first; make sure the switch on the handlebar is good, not grounding out, same with key switch and breaker (as Mick suggested), etc. When you put the new wiring harness in, verify you put the ignition hot on the correct circuit so it is hot with key on. It is an easy mistake to make, if key on gives power to starter but not to ignition, and key off powers ignition but not starter, it is wired wrong. I did it myself once.
Nolite Te Bastardes Carborundorum!
Old 7th August 2012
ironheadjunkie's Avatar
ironheadjunkie ironheadjunkie is offline
Sportster/Buell Model: XLCH Sportster
Sportster/Buell Year: 1961
ironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura aboutironheadjunkie has a spectacular aura about
Originally Posted by iron227 View Post
I have an issue of no spark with my 76xlh... Prev owner has dyna s ignition on bike and I have put new coil, Plugs, plug wires, and all new main wire harness including hand controls... .
Was the bike running before you installed new coil, etc.? What type of Dyna S Single-fire or Dual-Fire? Does it have ONE black modual up at the top (dual-fire) or does it have Two moduals one at top and one at bottom (single-fire)?
You can't drink all day, if you don't start in the morning.
Old 7th August 2012
I got the motorcycle out of dads garage after he passed away... It had a bad starter relay and solenoid....I completely went through bike from cams to push rods to rocker boxes and trans...new wiring through out and had the rings and pistons checked...almost all new everything... Except dyna s which has just one magnet... Dual fire I guess... That's goods to know as I am new to ironheads... I'm wondering opinions on if I do replace if I should go with points set up or back with dyna s???? Dual or single??? How do I test what I have to be sure that it is the problem... I will be trying the voltage test when I get off as ironmock suggested, anything else I should look for???
Old 7th August 2012
98ultra's Avatar
98ultra 98ultra is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: Ultra Classic
Other Motorcycle Year: 2009
98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about98ultra has a spectacular aura about
When I checked my Dyna S, I checked the HOT side of the coil first. There are two wires here. One goes to the kill switch (supplies the 12v) and the other is a white wire going to the Dyna S. With the key and run switch on, I had 12v on the hot side.
I then checked the other side going to the Dyna S module (Blue wire). At first I had some voltage, I forget what is was exactly but it was low, maybe a volt or volt and a half. I figured, Great, it is bad. I then turned the engine over and had 12v. It was switching on and off after all.
Next I changed the plugs and it fired right up.
Sold the Ironhead when I bought an Ultra. Missed the Ironhead so got another.
Old 8th August 2012
98ultra's Avatar
Is your wiring like mine? Two wires on one side and one on the other. The white from the Dyna S and the hot from the kill switch one one side and the blue from the Dyna S on the other?
The instructions said if hooked up wrong, it would destroy the module.
If hooked up right, do the voltage readings show the same as mine????? 12v on the hot and a change from 12 to 0 on the other.
Old 8th August 2012
98ultra's Avatar
I don't think I can see any metal under the boot. Do you have the plug wires pushed far enough into the coil??????? to make contact.
Last edited by Folkie; 15th August 2012 at 21:56.. Reason: Removed quote of deleted post
Old 8th August 2012
trappnman's Avatar
trappnman trappnman is offline
Sportster/Buell Model: XLCH- old school chop
Sportster/Buell Model #2: 1981 XL
Other Motorcycle Model: Norton HighRider
Other Motorcycle Year: 1971
trappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant futuretrappnman has a brilliant future
while no spark can be frustrating, in reality its not that bad.
Break it down to 1 of 2 things- do you have spark at the points (or EI)? Or juice there, but not at the plugs.
Then you know for sure, what circuit you are working on. It sounds like you do have juice to the points (EI)- I'd have a test light on that, while attempting to start it using the button. if then no juice its a problem with the starting system, not the ignition system per se.
if the coil is good, but still no spark at the plugs, then its either wires/plugs. If plugs and wires are good, then its got to be a short occurring when started button is pushed
have you tried bump starting it? if it is a short in the starter system, it should still start (if your coil/wires and plugs are good) when bump started. if it does not start doing that, then you can, for all practical purposes eliminate that system-
Old 8th August 2012
joey81iron85 joey81iron85 is offline
Sportster/Buell Year: 1981
joey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the roughjoey81iron85 is a jewel in the rough
Try the jumper wire trick remove 12v wire to coil then a jumper wire from bat + to coil+ if u have spark then its a wiring issue still no spark prob coil or ei ...I just replaced both on mine new coil went bad in 2 days also I believe u should b running a 3 ohm coil with ei 5 ohm with points
