0 Won't rev past 1200
Last Post: Aocasio
0 Engine dies when choke off
Last Post: ChicagoSlim
0 Oil use/smoking
0 Speedo cable lube
Last Post: a150bdriver
Last Post: Hank21113
Last Post: halfmt1
Last Post: Edster
0 Dynatek DC6-5 coil
Last Post: jordan1200
0 Head gaskets.
Last Post: sltm1
0 newby from Australia
0 blonde, brunette, red?
0 Dynamic timing the 2000i?
0 too bad
Last Post: robistro
Last Post: Crosshairs
0 seeking advices
0 Cream
Last Post: jakewalter
Old 13th August 2012
nrs_nate nrs_nate is offline
Sportster/Buell Model: 1999 1200 Custom
Sportster/Buell Model #2: 1998 1200 Custom
nrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enoughnrs_nate will become famous soon enough
Question sprayed carb cleaner on manifold seals,motor changed rpm?
My damn intake manifold seals keep going bad...I sprayed carb cleaner on the seal part while the engine was running and the motor bogged down on each seal, thus meaning the seals are bad? Also my plugs are too white for me, they were nice and grey. Is there any tricks to have longer lasting manifold seals?
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
1. What year bike, how many miles, how many seals?
2. How do you install them?
3. Leaking at head or carb?
1998 1200 custom,installed them with air cleaner back plate on, to make sure they line up..Never tried the the carb seal, just the head seals,
I would expect better success installing at the heads, first.
I seem to be replacing these quite a bit, how long -should- they last when correctly installed?
big andy's Avatar
big andy big andy is offline
Sportster/Buell Model: xlch 73
Sportster/Buell Year: sold
Sportster/Buell Model #2: 1997 1200s
big andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond reputebig andy has a reputation beyond repute
hi maybe you are running to lean and its getting to hot and causing the seals to go bad thats my guess they should last a long time if you are running the right mixture .
1997 1200s 1250 Hammer performance kit . Hammer performance billet inlet manifold .Hammer performance billet pushrod tube holders. energy one extra plate clutch kit . bronze oil pump drive gear upgrade
just ordered a seal kit, I'll be checking the plugs!!, mabey go with a bigger pilot jet
Although i read the plugs before the seals went bad and they were nice and greyish brown, So I might not be running lean, bike didn't spit or cough even blipping the throttle and there was no dexcel pop
Sportster/Buell Year: 1991
My manifold to head seals are originals, almost 22 years old. Should last a while I guess.
John
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Nate, when you're doing that test, it's very easy to get fooled. With most spray cans, if you press the spray can button all the way, I can about guarantee you that it'll get sucked into the air cleaner and change the rpm that way. You have to just barely spray around the seals to make sure you're testing them only.
Does the motor exhibit any other symptoms of an intake leak, hanging at a higher rpm before falling to idle?
Click Here to Contact Me
The bike runs pretty good as it sits. But i'll try to just barley shoot it on the head seal and only there
Thanks
