Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > BUELL MOTORCYCLE ZONE > Buell Motorcycle Bottom End
0 Not measuring any crankshaft endplay
Last Post: nakina
0 Manifold Leaks Gone !!!!
Last Post: cazz1000
Last Post: groovemeisterus
Last Post: rwharris
Last Post: tvon
Last Post: KCinSB
0 Lightning strike
Last Post: Screw Loose Dan
Last Post: x1_guy
Old 17th August 2012
Peterlover Peterlover is offline
Sportster/Buell Year: 81
Peterlover is an unknown quantity at this point
Default Help (timing the pinion gear to the crankshaft)
How do you time the pinion gear to the crankshaft? Shaft is splined from crankshaft. The pinion gear has a timing mark but is not pre-set to fit in any one place on the crankshaft. Does the crankshaft need to be at tdc or does the front or back pistion need to be at tdc.
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
The pinion shaft has a mark as well, line it up to the one on the gear. The mark is at the very end of one of the splines on the shaft.
If you have a Buell with a splined pinion shaft, it must be aftermarket?
Click Here to Contact Me
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Welcome to the Forum!
In future, please give your threads meaningful titles.
Folkie
South East England Riders
That or it is a very rare 4 speed RS 1200 or RR 1200? I own one of those but I do not know many folks who do.
aswracing's Avatar
No, the splined pinion shafts ended with the '87 model year. The only Buells ever made with the splined pinion shaft were RR1000's, with their XR1000 engines.
Old 18th August 2012
rocketmangb's Avatar
Welcome Aboard
I have a sick mind but you might want to change your user name.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Alto Carbonite Clutch
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Your pinion shaft should have this; line it up with the pinion gear timing mark ...
Welcome! to XLForum. Post these questions in the IronHead forum, here ...
Ironhead Sportster Motorcycle Talk (1957-1985)
http://xlforum.net/forums/forumdisplay.php?f=7
aswracing's Avatar
Good pic Iron Mick, that puts it to rest!
I once had a customer call me, telling me the valves were hitting the pistons and he had carved the bejeezus out of the valve pockets trying to get clearance and they still hit. This on a motor that had an S&S crank, which of course uses a splined pinion. He was convinced the cams were made wrong.
Took me awhile to realize he hadn't paid attention to that mark when you put his pinion gear on.
This was a noted engine tuner for a drag race buddy of mine ... but his experience was limited to 5-speed Evo's and I don't think he had ever encountered a splined pinion shaft before.
Anyway, he ruined the pistons
aswracing's Avatar
Also, do you think you ground on that pinion bearing race enough?
I remember having to do that to make cams fit. Scared the hades out of me.
