Last Post: ReddTigger
0 Solar battery charging
Last Post: Ranchero50
0 Lowboy frame conversion
Last Post: chevelle
Last Post: Naplesron
Last Post: Grumpy-Biker
0 Primary Oil INSANITY!
Last Post: randy3934
0 Left Side Exhaust?
Last Post: maltesefalcon
Last Post: blindfredy
Old 17th August 2012
MN Mailman's Avatar
MN Mailman MN Mailman is offline
Sportster/Buell Model: AMF XLS Roadster
Sportster/Buell Year: 1981
MN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of lightMN Mailman is a glorious beacon of light
Default Hastings rings confusion.....
On the second compression, I've got both a dot and an inside bevel........but the bevel is on the bottom ring face.
I.e. the dot is on the top of the ring, the bevel is on the bottom............so, both are supposed to be facing the piston top, but only one can.
Anyone seen this before with Hastings ?
Question Authority
Old 18th August 2012
millwright millwright is offline
Sportster/Buell Year: 1976
millwright will become famous soon enoughmillwright will become famous soon enoughmillwright will become famous soon enoughmillwright will become famous soon enoughmillwright will become famous soon enoughmillwright will become famous soon enoughmillwright will become famous soon enough
Wish I could help you!! But I would be just as stuck.
It is the bevel that counts. Facing the incorrect way it passes a lot of oil.
2nd ring bevel side down
top ring bevel side up
I do not have a lot of experience installing rings. I have a difficult time deciding if i am seeing a dot or just some random mark; the same deciding if there is a bevel or if it just looks that way to my old eyes.
But one time i got them wrong and i was using a quart of oil every 500 to 600 miles.
stroker104's Avatar
stroker104 stroker104 is offline
Sportster/Buell Model: 1200c
stroker104 is on a distinguished roadstroker104 is on a distinguished roadstroker104 is on a distinguished roadstroker104 is on a distinguished road
Dot up....bevel down....it's a reverse torsional ring
http://www.hastingsmfg.com/ContentDa...x?Contentid=72
brucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud ofbrucstoudt has much to be proud of
the subject has come up here before. not specifically with hasting's,but with several brand's. my s&s piston rings have both bevel's up. mick had mentioned the brand that he is running,were both direction's. [i,hope i,recalled this ,correctly]
MN Mailman's Avatar
I was thinking of that; like a scraper on the wall, and just found some good diagrams showing same on their site.
Thanks Mick.
Oops, i was reading the Wiseco instruction sheet. Presumably it is the same for the Hastings?
MN Mailman's Avatar
Then again, with an inside bevel, it won't contact the wall anyway
Hastings site says always put the dot up, when present.
geoff's Avatar
geoff geoff is offline
Sportster/Buell Model: XL1200 Low
Sportster/Buell Model #2: XLH1200 - Dearly missed
Sportster/Buell Year #2: 1994
geoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond repute
I have a set of Hastings in the shed, if you can't figger it let me know and I will see if the instructions are still with them.
Cheers
My life isn't completely about my Sportster. However, my Sportster makes my life complete.
MN Mailman's Avatar
Seems to be different Mick; Hastings says always have dot up, if one is present.
Inside bevel only applies (it seems) if there is no dot.
Dot trumps all it would appear, with Hastings.
