Last Post: Grumpy-Biker
0 Salutations y'all
Last Post: Alias Bob
0 no rear brake light
0 67 Sportster build
Last Post: ldurmon
Last Post: geoff
Last Post: goblin_dust
0 What's your helmet?
Last Post: lucky23
Last Post: cotton1
Old 21st June 2013
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Default Shunt vs. Series Voltage Regulators.
Hey gang, after seeing this post
http://xlforum.net/forums/s...09#post4463909
about stators getting whacked I investigated and used Aaron's from Hammer Performance recomendation about using a series regulator rather than the OEM shunt regulator our Sportys come with. I purchased a Cycle Electric series regulator from Hammer Performance and I will get it tomorrow and install it this weekend.
The difference between, a shunt regulator like our OEM and a series regulator is that the shunt regulator bypasses or "shunts" unused AC current from the stator to ground, even if our bike's system doesn't need the supplied AC current after rectification and regulation for charging the battery or running the lights, ignition, etc. That means the stator is always working "balls to the wall" and putting out max current...some to the DC system after the regulator rectifies and regulates it and the rest to ground.
I wanted to see this in action so I borrowed this from work...
a Fluke AC/DC clamp meter.
It has clamp jaws that are attached, or can be removed for remote measuring. Pretty cool!
I started the bike, (it was already warmed up from my ride home), and clamped the meter's jaws on to one of the AC leads coming from the stator to the OEM shunt rectifier.
I let the bike run for a minute to get the battery voltage up to 13.9 VDC so the only load on the regulator was the lights and ignition...about 9 amps. At idle, (around 950 rpm), the stator was already putting out more than the bike needed and shunting the rest to ground.
When I ran the RPMs up to over 2000, the stator was at full output, about 26 amps.
So, the OEM shunt regulator works as adverised and keeps the stator busy all the time.
The new series regulator I'm getting will only use what is needed by the DC system and let the stator breathe easy when it doesn't need to work so hard.
After the install I will post my findings and pics of the series regulator in action.
Old 21st June 2013
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
Good info Lux, thanks for sharing. I'm looking forward to the same measurements with the series regulator.
Click Here to Contact Me
Old 21st June 2013
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
a crap I knew I for got to do something. but I did test it at idle will get more info for you but at my batt volts were 14.4 at idle 1000 rpm didn't do a amp test just yet but I will can fell a hp improvement thought weathere it be the new stater or both the new reg and stater but the bike runs smother and faster or im crazy.
Old 21st June 2013
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER SYNDICATE
Scott...what's the Cycle Electric Part#?
Sic Semper Evello Mortem Tyrannis
Old 21st June 2013
LuxBlue's Avatar
Hey Rico!
Sorry, I seemed to have misplaced the actual Cycle Electric Part #. I'll post it here tonight when I get the regulator, provided it's stamped on somewhere or on the packaging.
If you order from Hammer Performance, the part # is 2112-0393. That's what I used when I ordered. See below:
Old 21st June 2013
07XL1200N 07XL1200N is offline
07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice07XL1200N is just really nice
Wow. That's a lot of amps it's putting out for no reason.
Old 21st June 2013
vspkent's Avatar
vspkent vspkent is offline
Sportster/Buell Year #2: 1973
Other Motorcycle Model: FLTRU
Other Motorcycle Year: 2016
vspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud ofvspkent has much to be proud of
Has anyone dissected a inop stator to see what failed on it ? Back in the day when I worked as a shop boy at a Alt/Starter rebuilder I saw many cheap solder joints fail on stators from heat.
Kent
Antagonist when antagonized, Yes Dude you're leaning the wrong way.
Old 21st June 2013
Jimg's Avatar
Jimg Jimg is offline
Jimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to allJimg is a name known to all
Kent
Good question. I doubt the stator much cares what it's putting out. Getting the load off the engine would be the attraction for me.
Old 21st June 2013
Rico 05R's Avatar
JESTER SYNDICATE
Thanks Scott.
Old 21st June 2013
Bob s hog's Avatar
it melts the wires about 1 inch from stator and load on the stator is every thing, why they run it to ground is stupid , you would never ask this out of a car alt because it would do the same thing once the systems fully charged the amps should go down to 4-5 amps but on a Harley system there is no break for the stator it littery working its ass of for nothing and I hope its nice this week end im woundering if my fuel milage will go up because with the new reg my stator wont be working it ass off .
