Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Lubrication and Lubricants
Lubrication and Lubricants You guessed. Here is where everyone can argue over oil.
Last Post: kaveebee
7 Long Road Trip advice
Last Post: jammantoo
0 Feeling in trouble.
Last Post: moparnut72
0 Back in Sporty Land
0 Diagnostic help
0 Value of a Boattail?
Last Post: Moon Wolf
0 spoke nipple tool?
0 Spring Seat Brackets?
0 Cylinder Piston kits
Last Post: SoonerSport
Last Post: valvebeater
Last Post: jcasella
0 Leaks
Last Post: seanq2208
0 Stock 883 cold blooded
Last Post: Diogenes415
0 z bars
Last Post: 201648Rider
2 Humble pie
Last Post: Sprtstr1200s
Last Post: gravydog
0 New to Harley
0 79 ironhead
Old 11th December 2013
sportsterdoc's Avatar
Other Motorcycle Model: Honda CB1100
Other Motorcycle Year: 2014
Originally Posted by Don Burton View Post
Doc. Are you sure that your rigidmount holds 3.6 quarts of motor oil? The rubbermount owner's manual had a misprint for a number of years which erroneously stated the motor oil capacity as being 3.6 quarts when the actual capacity was 2.8 quarts.
I agree that when one does a visual check, as shown in the owner's manual, in the primary one quart of lube is slightly overfill, at least in the rubbermount primary. That said, most people add a full quart which couldn't hurt anything except for the theoretical and not at all confirmed possibility of making the clutch stick a little bit more.
Don
Thanks for pointing it out. Maybe 3 quarts takes it to the top of the dipstick, thus a bit less than 3 quarts is a decent fill.
Originally Posted by gusotto View Post
I'd recommend buying the service manual as it answers many questions.
Have fun riding.
+1
BTW the transmission is separate and some riders use auto trans fluid in the primary, if it is suitable for a wet clutch.
zman08's Avatar
zman08 zman08 is offline
Sportster/Buell Model: nightster 1200
Sportster/Buell Model #2: xb9sx
Sportster/Buell Year #2: 2005
zman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of lightzman08 is a glorious beacon of light
Dont worry about that trans buddy!! I have been beating on my 1200's for three years now with no problems (just a clutch) Just keep the fluid changed and the primary chain adjusted. I personally run mobile 1 full syn 20/50 in my nightster and in my wifes Buel xb9. Engine and primary, I also change it religiously every 2500 miles. Just my .02 Have fun!!
08 nightster d&d bobcat, se tuner, v&h air cleaner. 05 xb9sx muffler mod
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster
Sportster/Buell Year: 01
ATF would work great, but you would most likely not be happy with the extra gear noise from the tranny that the thin ATF may cause in a sportster transmission
When H-D made/labeled their own Sports Trans Fluid, was it ATF?
xllent01's Avatar
Would you use fork oil in the trans too???
Too thin
My question was what was it that H-D sold under the Sport Trans Fluid label?
Just curious.
We already have a very lengthy thread on using trans fluid or otherwise.
xllent01's Avatar
Too thin
Just curious.
Too thin??? 7 weight ATF is not too thin??? Really??
Sport trans hasn't been made for quite some time now, what?? 2004????
Last I checked SportTrans fluid was a 75-90 gear oil suitable for wet clutch applications.
These oil threads....they really never go anywhere, do they?
kuzzi's Avatar
kuzzi kuzzi is offline
Sportster/Buell Model: XL1250N Iron
Sportster/Buell Year: 2012
kuzzi has disabled reputation
Just use molasses or milk whey.
OK, let me rephrase...inappropriate for gear shear.
Seriously, when I was using Sport Trans Fluid, I thought it was ATF.
Time to end this thread.
