0 1977 Bright Blue
Last Post: Airarbiter
0 THE Trainspotting Thread
0 Brake Squeek
0 Won't rev past 1200
Last Post: Aocasio
0 Mikuni HSR42
Last Post: jammantoo
Last Post: Keep it running
0 Paulie420 needs your help.
Last Post: The Crusher
Last Post: RandyMac
0 Not charging issue!
0 Range With EFI 4.5 Gal Tank
0 70 xlch clutch
Last Post: jwheld
0 Intro from New England
Last Post: felis
0 Where did it go?
Last Post: mwXL 2006
0 z bars
Last Post: Bryan83taco
0 2001 883 'customizing' log
Last Post: Jheitt
Old 16th April 2014
parsons913's Avatar
parsons913 parsons913 is offline
Sportster/Buell Model: 1200S Rat bike
Sportster/Buell Model #2: XLH
parsons913 is an unknown quantity at this point
Default buell jugs and pistons/ 883 heads
OK I've researched and have received great knowledge about what compression to expect (12.1:1) from Aaron at Hammer Performance, with bolting the XB12 cylinders and pistons to stock 883 heads. Has anyone done this? i know the compression is WAY up there but this bike is going to be run in the street et class at the strip so race fuel is fine. what other concerns are there? The bike is a 2007 883R fuel injected, screamin eagle breather and stock exhaust with no baffles with lollipops.
I'll be converting (ie 1250) during the off season, but came across a sweet deal (free) on the cylinder and pistons. i want to assemble a package that works together when i do the "real" conversion, so I really don't want to spend money on parts I'll just have to replace later. Also been thinking about E85 as a fuel seeing how the bike will be mainly track use.
Thanks for the help
Old 16th April 2014
hairy hairy is offline
hairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nicehairy is just really nice
I would worry about valves colliding with big cams and 883 heads.
Why the exhaust choice? Pretty bad combo and stock heads?
is it a budget thing?
2007xl883l: hammer1250, crush1200 heads, 600 cams, patriot defender, powervision.
Old 16th April 2014
parsons913's Avatar
I was told with stock cams clearance shouldn't be an issue. Budget for now. I will be adding better intake and exhaust shortly (gotta finish the sunroom). I figured it might be fun with race fuel. If I did the conversion now it would be a basic 1250 setup for 883 heads and I'd be changing the pistons out once I do the XB heads and cams later. Figured I could save some coin and still have a little fun.
