Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Accessories
Last Post: spacecoast
0 Ei
Last Post: trappnman
0 Oil??
0 Rear tire
0 Salutations y'all
Last Post: cotton1
0 Show your tank decals
Last Post: cotton1
0 What's your helmet?
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: RKN
0 Decman's Birtday
Last Post: Heff
0 67 Sportster build
Last Post: ldurmon
0 ##Dark side Tracker##Cam's ID?
Last Post: olddude13
Old 28th March 2008
Brick City Brick City is offline
Sportster/Buell Model: sporty 1200
Brick City has disabled reputation
Default Oil Pressure Gauge...
Im about to buy the Arlen Ness Oil Pressure Gauge for my 03 sportster.
I see where the gauge attaches to the top of the motor (just below the gas tank) but what I cant see is, where does the line connect into the engine? Does ayone have one, or even better, a picture? Thanks.....
Old 28th March 2008
gusotto's Avatar
gusotto gusotto is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Ultra Classic
Other Motorcycle Year: 2007
gusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant futuregusotto has a brilliant future
Should be instructions and enough hose to reach the needed connection.
Personally it would be more for looks as the oil pressure in a Sporty engine will vary, depending on engine RPM.
Low RPM, low oil pressure.
Higher RPM, oil pressure will rise.
Oil pressure light will do the same.
Adding a gauge just gives a place to leak.
Doesn't read the same way as a car.
"Beer has food value but food has no beer value."
2002 XL 1200 SE A/C & SE mufflers Mustang seat, Harley Hard Bags, Detachable Backrest w/Luggage Rack Kuryakyn Stop/Turn Signal Controller w/pulse brake, Pegs and Stirrups, Forward Controls, Memphis Fats Windshield
Old 28th March 2008
I still have a gift card from Christmas and its burning a hole in my pocket!
Thanks for the reply though..
Old 28th March 2008
gusotto's Avatar
I don't blame you for wanting to spend.
Lucky....
Old 28th March 2008
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
It connects where the oil pressure light switch is. There's an adaptor you use so you can screw the switch in as well, so you get the gauge and the warning light.
It's quite a job to get to where the switch is: under the oil filter. Well, it is on my '05 anyway, I guess it's pretty similar on an '03? It'd be a lot easier if you did it when you'd got the filter off for an oil change.
On mine the wire to the oil pressure light switch wasn't quite long enough to reach to the new location of the switch, and I had to extend it; easy enough to do.
Most of the joints are 1/8" - 27 NPT pipe thread: the hose to the gauge, the adaptor to the motor, switch to the adaptor. Not the hose to the adaptor, which is a different kind of ftting. The pipe thread joints need PTFE tape or similar to make them oil tight. I used Loctite 565 PST Pipe Sealant, which is available as H-D part # 99818-97 (never seen it anywhere else).
Here's my gauge:
I didn't use the Arlen Ness gauge (bought the kit without the gauge) because I didn't like the colours on the face. That's a VDO gauge. It isn't oil filled, and it does seem to be suffering from the vibration; in due course i will have to replace it.
Folkie
South East England Riders
Old 29th March 2008
Thanks Folkie! Funny, I just changed my oil 2 weeks ago.
Old 29th March 2008
Folkie's Avatar
Brass Nut
When I do replace the gauge I'm thinking of using that one with the engine turned face in the J&P, CC, etc catalogues, which someone said matches well with the silver faced speedo and tach.
Old 29th March 2008
I haven't seen the silver faced one, not even in the "08" J&P catalog, but ,I did read that the Ness gauge was a good one compared to other brand names.
Old 29th March 2008
Folkie's Avatar
Brass Nut
It's # 5700070 on page 927.
Old 29th March 2008
Thanx again..........
