0 07 883 Low .... lifting
0 83 XLH w/Velorex 562
Last Post: Scott
0 Hard to find Neutral
Last Post: ThenCameHarry
0 WTB - 95 mid control shift arm
Last Post: bordens
Last Post: 45Brit
0 Ultima Ignition Issues
Last Post: Serious Blac
Last Post: Brad
0 0Salt Flat Sporton
Last Post: Magneto Sportster
0 2009 Iron 883 Wont Start!
0 Shady shifter shaft
Last Post: randy3934
0 Sidehack for XLS
Last Post: 11B40
0 too much oil in primary
Last Post: 73HEAD
0 Brad's 1995 883 Hugger
Last Post: Brad
0 1998 883 Clutch Disc
Last Post: gary59
4 Snow a week ago, now a Tornado Watch
Last Post: fafcpa
0 Rear shocks ?
0 One cylinder working ...
Last Post: Bert fegg
2 WOW, This cracked? Wtf?
0 Do You Have Crash Bars/ Engine Guards?
Last Post: Azmarlin39a
2 Sloppy Throttle Feel
Last Post: XL_1200C
GRAYFEATHER (71), vonriken (70), The Crusher (63), madisonlink (60), hillbilly (59), mardyk (56), Blade (54), dmraco (51), jmcclure (44), Ryand36330 (43), nrrs (43), CRB1006 (33), Yoitsjustin1 (21)
Old 14th June 2016
Yochstein's Avatar
Yochstein Yochstein is offline
Sportster/Buell Year: 1984
Yochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud ofYochstein has much to be proud of
Default Primary Chain Adjuster Spring Install
I went to install my primary chain adjuster and I'm confused on how the spring is installed. Are there any pics or tutorials on how to do this correctly? This is for a late '84 model. I can post a pic of my adjuster tonight if you need to see what I have.
Thanks!
Old 14th June 2016
Racepres's Avatar
Racepres Racepres is offline
Racepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to beholdRacepres is a splendid one to behold
The adjuster spring is set-up to pull the adjuster shoe away from the chain...the locking adjuster bolt pushes against the shoe, and the spring to put tension on.
This shows the proper orientation
Old 14th June 2016
Yochstein's Avatar
Thanks Racepres. I studied my manual and parts catalog after I submitted the question and I kind of determined this would be the setup. I'll make an attempt to get it installed this evening.
Old 14th June 2016
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
The Parts Catalog really helps.
Old 14th June 2016
Yochstein's Avatar
The exploded views of the catalog helped better than the service manual.
Old 15th June 2016
Yochstein's Avatar
Does this look correct?
Old 15th June 2016
No.
D@mn! All i could find in my pics was another incorrect install ...
Old 15th June 2016
Yochstein's Avatar
I assumed this to be incorrect. I'm thinking it needs to be turned around with the solid part on the case and the gapped end on the tensioner itself. I'm wondering if the gap is too wide and needs to be compressed together a bit. It slips off the tensioner this way as of now.
Old 15th June 2016
When installed correctly no parts hang down below the engine case.
Old 15th June 2016
Racepres's Avatar
Ain't Rocket science...If installed the other way around it would be obvious...
The damn primary cover hooks the "leg" hanging loose there...
The "leg" needs something to push against to keep the shoe in tension away from the chain...
And when the primary cover is installed...correctly, nothing "hangs down" either!!!
