0 Salutations y'all
0 New member in MD
0 Primary Oil INSANITY!
0 Decman's Birtday
Last Post: Outtakes
0 Oil??
0 Ei
Last Post: trappnman
0 What's your helmet?
Last Post: goblin_dust
Last Post: spacecoast
0 Rear tire
0 Show your tank decals
Last Post: cotton1
0 New England 2018
Last Post: joes95bobber
Last Post: cotton1
Last Post: Heff
Old 18th April 2008
badiron74's Avatar
badiron74 badiron74 is offline
badiron74 is an unknown quantity at this point
Default backfire through carb....
all you resident guru's, what would cause a back fire through the carb? It only happens above 3000 rpms while cruising. I have an s&s super e with a 29.5 idle speed jet and a 68 main jet. any help is appreciated. Thanks
74' Iron XLCH
Punched .050 over
Cams / 10.5:1
S & S E shorty
Crane HI-4 Dual Fire Ignition
Raked to 40*
(muffler dragger)
Old 18th April 2008
badiron74's Avatar
after doing some research it seems that it is because of a lean condition, but it just seems odd that it is only above 3000 rpm's. I would think that it would be happening at all rpm's. When I pulled the plugs they looked black and sooty. Any one have any advice.
Old 18th April 2008
Ivan RoachCoach's Avatar
Banned
Default Above 3000 rpms you're well into the main jet, that may be...
...where you're a little lean.
Your intermediate jet selection seems a little rich at 29.5 for a 1000cc motor.
That's on the high end of the S&S specs, and they're generally on the rich side.
Check it out: http://www.sscycle.com/modules/instr...ds/51-1012.pdf
Old 18th April 2008
RiderOnTheStorm RiderOnTheStorm is offline
RiderOnTheStorm is an unknown quantity at this point
I had that problem and found out it had absolutely nothing to do with mixture.
It sometimes hiccuped/coughed even when it was hot and I found out it was the stock worn out diaphragm in the carb.
Old 18th April 2008
Banned
Default What diaphragm? He's running...
...an S&S Shorty E.
Old 19th April 2008
sorry I skim. =)
Old 19th April 2008
madhatterxlch's Avatar
madhatterxlch madhatterxlch is offline
Sportster/Buell Model: Ironhead XLCH
Other Motorcycle Model: FXDB Street Bob
Other Motorcycle Year: 2007
madhatterxlch is on a distinguished roadmadhatterxlch is on a distinguished roadmadhatterxlch is on a distinguished road
Might want to check for the old air leak. At 3000 or above your engine has more vacuum so you might have a leak that doesn't present itself until the higher vacuum sets in.
1974 Ironhead XLCH that's Broke, 1985 Ironhead XLH & 2007 FXDB.
Old 19th April 2008
SpringerSam's Avatar
SpringerSam SpringerSam is offline
Sportster/Buell Year: 70
Sportster/Buell Model #2: Softail Springer
SpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished roadSpringerSam is on a distinguished road
You may also want to check your timing advance mechanism...
Old 20th April 2008
keeno keeno is offline
Sportster/Buell Year: 1968
keeno will become famous soon enoughkeeno will become famous soon enoughkeeno will become famous soon enoughkeeno will become famous soon enoughkeeno will become famous soon enoughkeeno will become famous soon enough
Your main jet is to lean, 3000rpm is where the intermediate system changes to the main jet circuit. Go to a 70 main and try again. I agree with Ivan though 29.5 is a bit rich for the intermediate jet 26.5 is about right.
Old 21st April 2008
badiron74's Avatar
I started out with the 28 jet and had to back my mixture screw out 3 turns before she would idle good. According to s&s I am only supposed to be out 1 1/4 turns. Keep in mind that I am bored .050 over. I will swap out the main to a 70 and see if that helps. I will keep you guys posted. Thanks.
