03 xlh 88"
New Owner
Last Post: Brad
....1
20th December 2016
Posts: 1,812 Sportster/Buell Model: XLCH Sportster/Buell Year: 1976 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 74/5
Originally Posted by 45Brit
I do like that kit of transmission tools.
Santa brought me that last year. It does seem pretty good. Will be trying it out over the holidays this year as I have a new primary chain to fit. Have some reading to do first as it'll be the first time for me
Paul
Sent from my SM-G900T using Tapatalk
20th December 2016
Posts: 102 Sportster/Buell Model: Sportster Custom Sportster/Buell Year: 1997 Sportster/Buell Model #2: Ironhead Sportster Sportster/Buell Year #2: 1973 Other Motorcycle Model: Honda GL1000 Other Motorcycle Year: 1978
I used my kit earlier this year, and I was happy with the way everything worked. It was worth the money to me.
DirtRoadCowboy.com
21st December 2016
Posts: 266 Sportster/Buell Model: XLH Sportster/Buell Year: 1980 Sportster/Buell Model #2: XLH Sportster/Buell Year #2: 1975 Other Motorcycle Model: FLH Other Motorcycle Year: '82
OK, this worked so well for me, I thought I should re-post it here. $10 mainshaft line hone. http://xlforum.net/forums/s....php?t=1996190
21st December 2016
Posts: 166 Sportster/Buell Model: XL1200V Sportster/Buell Year: 2014 Other Motorcycle Model: Triumph Thunderbird 1700 Other Motorcycle Year: 2010
I am amazed by the ingenuity i see in this thread.
Storm P. has not lived i vane.
[URL=http://s1379.photobucket.com/user/brny55/media/003_opt_zps7jiaxmck.jpg.html][IMG]http://i1379.photobucket.com/albums/ah154/brny55/003_opt_zps7jiaxmck.jpg[/IMG][/URL]
Money can't buy you love or happiness, but it can buy you a Harley, and that is damn close
14" Arlen Nees brake, Cobra Speedster shorts exhaust, Cobra ProFlo air intake, Hammer Perf. 570 cams, Seat upgrade, Progressive 970 piggyback shocks rear, Progressive monotube fork catridge, 4.5 gallon tank, Michelin Commander 2 tires, 9 degree Widebody Chopper Supply rake kit, Kuryakun ISO grips, Chrome rear swinger, TTS modified tune.
8th January 2018
Posts: 891 Sportster/Buell Model: 1968
Special tools
I think TheDoctor71 made one of these, but the pics are missing and it’s back before the Photobucket fiasco.
Took a socket (ID larger than the sliding top hat spacer) and hogged out most of the teeth. Have a box of junk sockets for such purposes.
Cut some slots and made some little ears.
Cut a stepped bar in the lathe to fit the bearings. The big end got pressed into the socket. The step sits 3/16” below the business end of the socket.
Held it together with a hose clamp for welding.
I am not good at tig welding, but trying to use it for everything so I get better, unless I know I can do it better with a different machine.
Anyway, it seems to work.
Al
8th January 2018
Posts: 323 Sportster/Buell Model: XLCH Sportster/Buell Year: 1968 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1974 Other Motorcycle Model: FLHR Other Motorcycle Year: 2002
Very nice Al, can't beat the homemade!
8th January 2018
Way more elegant than my compensator nut socket!
8th January 2018
Posts: 3,180 Sportster/Buell Model: xls 1000 Sportster/Buell Year: 1980 Sportster/Buell Model #2: xls 1000 Sportster/Buell Year #2: 1983 Other Motorcycle Model: 1200 Chopper XL Other Motorcycle Year: 1990
Home made polishing compound from Jewellers rouge, Mineral Oil, used soap bars.
Paste is in old cut coffee can
8th January 2018
Posts: 6,751 Sportster/Buell Model: Xl1250S Sportster/Buell Year: 98 Other Motorcycle Model: Kawasaki Vulcan 500 Other Motorcycle Year: 95
I have added what I could retrieve from this thread in the Sportsterpedia: http://sportsterpedia.com/doku.php/t...k:ref:tools100
Reason: updated link
9th February 2020
Lifter holder remover "Special Tool".
Many will recognize this as an automotive battery terminal puller.
Remove the pushrod adjuster leave the cam in and push on the lifter.
