0 Ei
0 24633-77 Breather assembly
0 Newbie CV rebuild
Last Post: Matt Black
0 ‘68 XLCH...transmission
0 2016 48 Hesitating
Last Post: 201648Rider
Last Post: Larry May
Last Post: Yochstein
Last Post: Jheitt
0 Salutations y'all
0 New member in MD
0 New from Utah
0 New England 2018
Old 1st March 2010
tarathatcher tarathatcher is offline
tarathatcher is an unknown quantity at this point
Smile 1988 1200 Sporty Ignition Module
I currently have 2 ignition modules in my garage that will fit my 88 Sporty 1200. Which one is better? I can't find much info other than the rev limiters are different... the first one is part #32597-96. 6800 rev limiter. The second one is: part #32420-87B. 8000 rev limiter. Is the rev limiter the only difference? I'm trying to determine which one I should use. My Sporty's engine is a stock 1200 (only 8,000 miles) with Andrews V4 cams and Vance and Hines Straight Shots exhaust. Any help would be appreciated.
Thanks,
Tara
Old 1st March 2010
fourteen fourteen is offline
Sportster/Buell Model: XLH 883/1200
fourteen is an unknown quantity at this point
There normally is an additional marking on the module that tells you what curve it uses. E.g. on the 32420-87B that I am using in my 93 1200 the additional marks include "1200-K". The "K" means the module uses the K curve.
Does the 32597-96 have any additional printed stuff on it? Unless you have already changed some wiring on your 88, you may need a different plug (or harness 32408-90) to fit that module on your bike.
Old 1st March 2010
the 32597-96 module does have 1200-KSE stamped on it. I have the adapter harness sitting on my table, so I will be able to hook it up ok.
1988 1200 Sporty
1968 XLCH Sporty
2006 Dyna Super Glide 35th Anniversary
Old 1st March 2010
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
This one is a SE module. The other one sounds like a stock module.
Old 1st March 2010
Then it uses the K curve as well (max advance at 40 degrees). Thus, the only difference between your modules is the rev limit, I believe.
If you decide to run the 32420-87B, I might be interested in the 32597-96 if you want to sell.
No, 32420-87B is also a SE module.
Old 2nd March 2010
williamv1203's Avatar
williamv1203 williamv1203 is offline
Sportster/Buell Model: 1203 XLH/Buell Hybrid
Other Motorcycle Model: FXDWG TC88
Other Motorcycle Year: 2000
williamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to beholdwilliamv1203 is a splendid one to behold
Thumbs up
Use the 8k module...
Old 6th March 2010
SHIPCHIEF's Avatar
SHIPCHIEF SHIPCHIEF is offline
Sportster/Buell Year: 1984
Sportster/Buell Model #2: 'Big Sportster' FXR
Sportster/Buell Year #2: 1988
Other Motorcycle Model: Ural Patrol, Yamaha XS650
SHIPCHIEF is an unknown quantity at this point
My stock module failed in the first 2 years.
The SE module I bought for it is still running strong, 20 years later.
The 'long harness' was not in stock at the dealer, so I just soldered the wires together.
I'm not looking forward to the next failure.
Most engines don't die a natural death, they are murdered.
Old 18th March 2010
90sportster's Avatar
90sportster 90sportster is offline
Sportster/Buell Model: 883/Hammer 1250
Sportster/Buell Year: 1990
90sportster has disabled reputation
I did a 883/1200 conversion on my 90 sportster.I used ignition module part # 32432-91A.
It uses the "J" curve and has a 6800 rev limiter. If you do a little research, you will find this is one of the best HD ignition modules to use for a 1200.
Old 18th March 2010
Jafa39's Avatar
Jafa39 Jafa39 is offline
Sportster/Buell Model: XLH1100
Sportster/Buell Year: 1986
Jafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enoughJafa39 will become famous soon enough
I wouldn't use the 8k rpm module......Sporties don't last too long if you over-rev them...tops of pistons attempt to become space junk usually...the 6800 rpm limit has been worked out by Harley to keep all the expensive parts inside the cases.
In my experience this is the same for all long-stroke motors.....piston speed is too high to go sodding about with rev limiters...oh lots of people want the increased limit buts its just the usual pissing match...a lot has to be done to a H-D (or a Ducati for that matter) before you can safely exceed the rev limit...
Shake, rattle and roll...is there any other way to travel??
Old 19th March 2010
Exclamation
In my experience this is the same for all long-stroke motors.....piston speed is too high to go sodding about with rev limiters...oh lots of people want the increased limit buts its just the usual pissing match... a lot has to be done to a H-D (or a Ducati for that matter) before you can safely exceed the rev limit...
Just because it's capable, doesn't mean you have to go there...
