Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Accessories
Last Post: Aden
0 THE Trainspotting Thread
0 48 Handling
Last Post: 201648Rider
0 Mid's or rear sets
Last Post: gusm2
0 Blow thru setup
Last Post: Sideshift92
0 -75 ironhead, My first HD
Last Post: blindfredy
0 91 oil in cam cover
0 Safe to run 2 master links?
Last Post: Reverend G
Old 29th April 2010
AussieGazza's Avatar
AussieGazza AussieGazza is offline
Proud 2000 XLH 1430 Owner
Sportster/Buell Model: XLH 1430
Other Motorcycle Model: Piaggio X9 250
AussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really niceAussieGazza is just really nice
Default Latest Sportster Parts Catalog is On-Line
My local dealer has put up the latest parts catalog (2.1Mb).
It is available here.
Garry
[SIGPIC][/SIGPIC] AussieGarry
I'm not a complete idiot -- Some parts are missing (but on order from EBay).
Supertrapp 2-1 with 18 plates and closed end cap, 11.5" 412 Progressive with Heavy Duty springs and Progressive fork springs. Mikuni 45carb/SE 44 manifold. NRHS 88" with Stage 2 ported 04 heads with 15 degree squish band, SE .536 cams, crane roller rockers and lifters, NRHS Hurricane Adj Pushrods and Collapsible Covers. Ultima prog ign. 180 main jet, 3 turns, 20 idle jet and 97 needle at 3rd notch. AIM 240 Clutch. LRB Z Plus Brake Pads on dual front brakes. Kuryakyn Boss Blade Levers + Forcewinder XR A/C.
Old 29th April 2010
paul618's Avatar
paul618 paul618 is offline
Sportster/Buell Model: 2002 883C
Sportster/Buell Model #2: 2005 VRSCB
paul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nicepaul618 is just really nice
404 -- The requested document was not found on this server.
Old 29th April 2010
Brad's Avatar
Brad Brad is offline
Senior Master Bolter Oner
I was able to get it. But it's the parts and accessories catalog. (not the parts manual with the exploded drawings)
Old 29th April 2010
Sorry! Yes accessories, not parts manual.
Old 29th April 2010
merc merc is offline
Sportster/Buell Model: Custom
Other Motorcycle Model: Suzuki GN400
Other Motorcycle Year: 1980
merc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant futuremerc has a brilliant future
i got the 404-not Found too
must be something set up in out computers that does not allow some sites to open.
Probably something related to virus or pop up protection.
Old 29th April 2010
Try a right click and 'Save Target As'?
Old 29th April 2010
jharback's Avatar
jharback jharback is offline
Other Motorcycle Year: 1998
It's a .pdf document so in order to view it in your browser you need to have the add-on. Do as AussiGaza says and right click and save it. Then open it with Acrobat Reader.
Jim in Italy
'93 1200
WetDreamz Pipes
16" Carlini Apes
Old 29th April 2010
nope=that open this thread again.
Can you post the http but put 2 x's where the T's are so it won't be a link.
I'll try typing it in to see if I can find the site.
Old 29th April 2010
Full path is:
"http://www.robboshd.com.au/images/images/downloads/Parts/sportster%20cat.pdf"
Old 29th April 2010
turn8a turn8a is offline
turn8a has disabled reputation
[quote=Brad;2591902]I was able to get it. But it's the parts and accessories catalog. (not the parts manual with the exploded drawings)[/quot
bikebandit has the parts manual
http://www.bikebandit.com/harley-dav...arts/oem-parts
