Last Post: gravydog
0 1972 tank fitment
Last Post: 72 Ironhead XLH
Last Post: Airbozo
Last Post: nibroc
0 going tubeless in pretubeless 9 spoke mags
0 Help me with gas cap...
0 Sportster or Street Bob
Last Post: joes95bobber
0 1977 xlch starter issues
Last Post: russzx6
0 Primary Oil INSANITY!
0 Lowell, MA weekly moto night (Tuesdays)
Last Post: tvon
0 Blues & Brews 2018
Last Post: tvon
Last Post: tvon
Old 19th October 2010
xlproject's Avatar
xlproject xlproject is offline
xlproject is an unknown quantity at this point
Default Ironhead sportster piston mods (what have you done to better performance)
Here are my machined pistons for the 1000 cc xlcr.
56 g = 1.97534 oz lighter than forged wiseco pistons
24.16 g = 0.852218 oz lighter than stock sportster pistons
fdny37's Avatar
fdny37 fdny37 is offline
Senior Master Bike Builder
Sportster/Buell Year #2: 1968
Other Motorcycle Year: 2014
Get them coated and put on Total Seal Gapless rings and you will be a happy man.
xlproject's Avatar
They will get coated next.
Still got a trick up my sleeve. I´m machining new wrist pins right now.
I can´t find the the top gapless rings on the total seal web site. Anybody got a part number??
Buy the way the pistons are cnc machined .020 oversized wiseco pistons.
bobber58 bobber58 is offline
Sportster/Buell Model: XLH bobber
Sportster/Buell Year: 1964
Sportster/Buell Model #2: XLH
Other Motorcycle Model: 883 Iron
Other Motorcycle Year: 2010
bobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of lightbobber58 is a glorious beacon of light
I'd spend some time hand finishing them. Round off those ridges on the tops of the domes, especially on the corners. Those sharp angles will create hot spots that can lead to pre ignition, then coat them. Have you measured the new domes? How much compression are you gonna lose? A light weight piston won't give you a performance advantage, but they will be a little easier on the rods at high rpm, but the lower compression will give you a performance difference.To really gain a longevity advantage you would need to go with a big bore and shorter stroke to get the piston speed down. That's what they did with the Evo's. Just wondering what you are trying to accomplish by lightening the pistons?
xlproject's Avatar
Should give me better acceleration quicker throttle response (less rotating mass). Also hoping to get less stress on the rod and main bearings. Better oiling on the wrist pin´s and wrist pin bushings (2 extra oil holes).
Better top ring sealing (vertical gas ports).
The comp ratio is 9.5:1
Should work great with the cams i got.
Old 20th October 2010
I feel like I'm stating the obvious, but have you tried searching by the bore size?
http://www.totalseal.com/SearchByBore.aspx
fdny37's Avatar
Try calling Total Seal I'm sure they will help you out.
Just a question, why do you want the top ring gapless? I am running the second ring gapless in my 93" stroker with 10.5 pistons and it works just fine. I also put gapless in my stock 900cc '68 XLCH and the bike runs great.
FDNY, both rings or one only on the '68? Kick start only I assume?
fdny37's Avatar
Only one ring is the gapless ring and it is usually the second ring. That is the setup I'm running on both my Sportsters and I highly recommend the Total Seal gapless rings.
http://www.totalseal.com/TechPage.as...plessPistRings
misterT's Avatar
misterT misterT is offline
Sportster/Buell Year #2: 1976
That is the same set up I have used in several car engines I have built, In fact you can buy just the second ring set from total seal if your pistons came with a set already.
