Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Fix My Hog
Get Lowered
Ricor Shocks
forks, problems, suspension
Old 21st January 2011
Betty254's Avatar
Betty254 Betty254 is offline
Betty254 is an unknown quantity at this point
Default Forks are off
I was recently involved in an accident on my nightster (not fun). Not any major damage but I did go down on the right side. My bars took most of the abuse but now it feels like my forks are off. When I lean right it seems very loose and when I lean left it seems tight. Also when I'm riding a straight line it wants to gradually go right (as if a car/truck had a bad alignment). Is there any way I can fix the issue or do I have to bring it to the dealer?
You may all go to Hell, and I will go to Texas.
-Davy Crockett
devilshound's Avatar
devilshound devilshound is offline
Other Motorcycle Model: BMW R75/6
Other Motorcycle Year: 1976
devilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura aboutdevilshound has a spectacular aura about
Just a thought. You may want to double check the rear wheel alignment. That's been known to make 'em track funny.
-DH
Old 22nd January 2011
XLXR's Avatar
XLXR XLXR is online now
XLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to beholdXLXR is a splendid one to behold
Loosen and retighten the front end, the forks may be twisted. There is a certain procedure to follow, but I'm too "tired" to remember what it is.
Ricor test rider for IAS Shocks, Intiminators and Vibranators. Works Dual Rate fork springs, fork brace, Avon Venom X tires, loosen drive belt, and set frame rails level to floor. Read the "7 Pages of Suspension" thread in the Suspension Sticky Index to learn how to fix your suspension.
jharback's Avatar
jharback jharback is online now
Other Motorcycle Year: 1998
As XLXR said, loosen the front forks. Then get out your service manual and follow the procedure for tightening 'em up and be sure to adjust the "fall away."
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
xllent01's Avatar
xllent01 xllent01 is offline
Ride That F'N Sportster!!
Sportster/Buell Year: 01
Loosen and realign the handbars also, then retighten when straight, most likely the cause of your alignment issue
just loosen the triple tree pinch bolts top and bottom to realign the triple trees, NOT ALL AT THE SAME TIME, cause the front end will drop out..
the FM is really NOT specific about the proper fall away method,
as long as the stembolt has NOT been loosened or re-torqued.. fall away shouldn't even be an issue..with the bike being lifted front wheel on, tighten it down until you have resistance. Then back off until it is smooth, swinging the front end from side to side making sure it has no resistance or no binding at all.
just double check proper alignment of the triple tree's and handlebars which most likely took the brunt of the fall causing your alignment issue..
RTFS
Sportsters are like prison shanks, small..fast..DEADLY!
When life throws a curve...lean into it and open the throttle.
The wheels beneath me, the road ahead of me..These are the reason's why I ride!!
khaskins's Avatar
khaskins khaskins is offline
Sportster/Buell Model: Sportster 883L
Other Motorcycle Model: Honda CB350 Cafe Style
Other Motorcycle Year: 1970
khaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud ofkhaskins has much to be proud of
If you are not familar with these procedures, you should have the work done by a professional. Having the front end setup wrong can cause some serious problems when riding at speed.
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
