Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Rubber Mount Sportster Motorcycle Talk (2004-2006)
Lickscycles
Zippers Performance
Fix My Hog
Foxcreek Leather
NRHS
Old 14th February 2005
Gho Gho is offline
Sportster/Buell Model: 1200c Sportster
Other Motorcycle Model: And some dirt bikes
Gho is an unknown quantity at this point
Default Adjust preload on the rear shocks
Hey! Some help please.... Has anyone adjusted the preload on the rear shocks on a 04' custom?.Any tips? Special tools?
Gho
willprevale's Avatar
willprevale willprevale is offline
Other Motorcycle Model: '06 Scarabeo
willprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura aboutwillprevale has a spectacular aura about
What kind of shocks, how much do you weigh, two up or solo, what does she weigh. A littil info please.
What anyone else thinks of me is none of my business.
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
IronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud ofIronMick has much to be proud of
Haven't seen on '04 but the tool i got with my Honda Shadow 750 many years ago has been perfect for all of my bikes: Yamahas, Hondas, and Sportys. They still use the same one for all the new Hondas. I'd get one at the Honda dealer.
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Leg Man!
LuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant futureLuxBlue has a brilliant future
Pick up a shock spanner wrench at your local stealer.
Jester Mafia Member * TC88A Ignition With Rico's Jester III Map *
Gho Gho is offline
I weigh 180# She weighes 120#. Stock shocks.
At that weight, I'd say the Progressive 412s set on the third notch will do and progressive springs upfront with 15w oil and yer good to go.
Gho Gho is offline
Thanks I was wondering if I had to just lift the bike up, or unbolt them, or if there was a trick to it.
LuxBlue's Avatar
Leg Man!
No trick, spanner fits in grooves, just make sure left and right are the same. I've heard you can wrap a rag around the adjuster and use pump pliers but I wouldn't suggest that!!!
Gho Gho is offline
Thanks LuxBlue, That is very helpful. Looks like we have the same ride.
Kenny's Avatar
Kenny Kenny is offline
Sportster/Buell Model: '05 XL1200C
Sportster/Buell Model #2: Buells '07 XB12Ss, '05 P3
Other Motorcycle Model: Honda Dirtbike and Quad
Kenny is an unknown quantity at this point
Similar Threads
Just finished upgrading my run-turn-stop rear lighting system mikeabe Sportster Motorcycle Motor - Top End 19 18th May 2005 21:02
Installing Replacing Rear Shocks SamIam Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 7 10th May 2005 11:34
1200S shocks - adjusting spring preload RSK Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders 8 2nd May 2005 02:53
Are rear shocks serviceable??? NXC1978 Chopper & Bobber Talk 15 16th March 2005 02:45
changing rear shocks... harleymanjay04 Sportster Motorcycle General Discussion and Problems 27 14th January 2005 02:04
