Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
Primordial Cycles
Ironworks Magazine
NRHS
The Dart Flyscreen
Old 22nd July 2006
dieselnutz dieselnutz is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 91
dieselnutz has disabled reputation
Default oil line routing to the pump
Trying to assemble a basket case and need to know which oil line is the feed and which one is the return on the oil pump on a 91 Sportster? There are two hoses coming off the pump one to the front of the bike and one to the rear.
Old 23rd July 2006
DV8 DV8 is offline
DV8 has disabled reputation
On my 94, there are 3 lines coming off the pump.
The lower one on the back of the bowl is the feed.
The lower one on the front of the bowl goes to the filter.
The upper one on the side is the return to the tank.
