famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27) |
28th January 2007
Posts: 316 Sportster/Buell Model: XL883 Sportster/Buell Year: 2005
Trick BREATHER Setup !
Back in the middle of getting parts for my Stage 1, Joe Dirt posted a pic of their Stock Triumph Breather Setup http://xlforum.net/vbportal/forums/s...t=40220&page=4
a few people posted how to try in on their Sporty........ Basically some hose from the crossover tube goes into a "T-fitting", top goes to a small piece of hose w/ a breather attached, bottom goes to a longer piece of hose that has a fitting w/ a cap on it and is tie wrapped under the bike on the frame, loosen the hose clamp on the cap fitting and let it drain, when you change the oil....... Well, when I did my Stage 1, I built that Breather Setup AND IT WORKS GREAT !!! No oil in the A/C, No oil on the bike, No oil on my leg ! WOOT !
Just changed the oil (have a fresh, clean fill of MOBIL 1 w/ Metalon M) !
..... just after I finished draining the oil, I pulled the hose clamp off of the breather hose that I have running under the frame (and tie wrapped on the under side of the frame) and some oily semi-clear liquid went into the drain pan, clamped it back up, filled the oil tank and had a great afternoon ride !
...may the wind be in your face and the Lord in your heart"
- FTW
-- It's about the Ride!
For those who have experienced it, no explanation is necessary; for those who haven't, no explanation is possible.
- If you can read this thank a teacher.
- If you can read this in English thank an American Soldier ! :usaflag
TAXES PAID !!! ......MandMCycle ROCKS !
HP+ slip-ons, Zipper's Air Cleaner w/ K&N, #45 Re-Jet, Mixture Adjustment, Custom K&N Breather setup
- "If loud pipes save lives, imagine what learning to ride correctly could do!"
....as they said that movie:
Elwood: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses" ...
Jake: "Hit it !"
28th January 2007
Posts: 311 Sportster/Buell Model: sportster 1200 Sportster/Buell Year: 2004
That oily semi clear liquid out of the pipe will have probably been water condensed out of the breathers and pipes.
30th January 2007
Posts: 37 Sportster/Buell Model: XL883R Sportster/Buell Year: 2006
Can you show pictures of how the hose is connected to the crossover tube?
Where did you get the breather?
What AC do you have?
-- Chris S.
30th January 2007
Posts: 135 Sportster/Buell Model: Sportster 1200 Custom Sportster/Buell Year: 2001 Sportster/Buell Model #2: Sportster 1200 Custom Sportster/Buell Year #2: 2004
What did you use to cap it off with?
2001 Sportster 1200 Custom with Forcewinder Intake, Force Streetfighter Pipes W/ Baffle, SE 575 Cams, Mikuni 42, Twin Tec Single Fire Cone Ignition, 04 Heads - NRHS Stage 2, NRHS 1250 Kit W/ 10.5:1 Pistons, 12" Apes, and Custom Flame paint job.
4th February 2007
It is a Zipper's Air Cleaner (with a NPT cap in the backing plate, where the breather hose was supposed to go), Great A/C btw !!!!
http://www.zippersperformance.com/ca...=572&prod=2050
The breather is a K&N http://www.knfilters.com/vent.htm
Steel Base Crankcase Vent Filters - One Piece Design For Competition Use
Steel base crankcase vent filters have vent tubes added to their base. Filters consist of a one piece design with a rubber or chrome top. Filters with mounting studs can be mounted remotely, but require vent hoses and clamps. Filters mounted direct can be pressed into rubber grommets in valve covers. All baseplates are chrome plated. Tubes are zinc. (think it was a 62-1090, but I need to check !!) got it from MandMCycle
The " end cap" is tie wrapped under the frame, using 150# tie wraps.
- tie wraps go around the double female coupler (when I changed the oil, I cut 1 tie wrap, drained it, replaced the tie wrap.... and rode on)
edit - all of the stuff: Hose, hose clamps, double female coupler and end caps @ Auto Parts store... Had to try a few different places, don't remember what I got at AutoZone vs. Advance vs. local shop ?
edit #2 - the "chrome" looking right angle bracket (holding the filter in place) is from the wood-type bracket dept. at Lowes (had to drill out the 1 screw hole for the breather filter)
Sorry not a good picture OR "drawing"....... I'll try and get some better pics posted (may not be right away though...)
2nd March 2007
Posts: 5,599 Sportster/Buell Model: XL 1200 R SOLD! Sportster/Buell Year: 2006
Very cool setup!
16th March 2007
Originally Posted by Don Burton
Very cool setup!
Thanks ! deciding on the next project..... AND trying to get some riding in.
16th March 2007
Posts: 2,957 Sportster/Buell Model: Buell 1125CR Sportster/Buell Year: 2009 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1964 Other Motorcycle Model: Kawasaki Ninja 250 Other Motorcycle Year: 2006
I'll be doing something similar on the Buell.
If you want to get even more trick, get a petcock to fit into the 3/8" hose.
16th March 2007
Posts: 462 Sportster/Buell Model: sportster 883/1200 Sportster/Buell Year: 2002 Other Motorcycle Model: FLHT Other Motorcycle Year: 2009
Thats pretty neat, prob try that on mine
Thunderstorm heads stg 2
1250 bore, SE 497, SE coil and ignition
RB Racing LSR 2-1 pipe
progressive10" lowering shocks
custom made flame seat
smoke'n big twins (PRICELESS)
7th June 2007
working great...... no problems.....
| Thread Tools |
| Display Modes |
Hybrid Mode
