29th June 2009
Posts: 184 Sportster/Buell Model: Ironhead Sportster/Buell Year: 1981 Other Motorcycle Model: 1964 Triumph 3TA
Unbelievable
Hi all,
Yesterday I sorted the creeping clutch problem. I took the bike out for a test ride. The bike was working brilliant. On my way back to the garage, the front brake locked up on the disc and through me off the bike. I was trapped under the bike but luckly a guy walking by helped get the bike off me and up on it's wheels.
The damage, the left side forwards took the brunt of the fall. I had to kick them straight so I could use them. I had taken some tools with me just in case. Took the bolts off the caliper but it was stuck solid. I loosened the banjo bolt to release the pressure and the caliper came off. It was scorching hot, wrapped it in a rag and cable tied it to the bars.
It was very interesting riding with one brake. Got back to the garage to find the gears don't work. I can't believe it, I was already to take it for an MOT. This bike just doesn't seem to want to be on the road. Every time I fix a problem, wallop up pops half a dozen more.
What could have made the brake lock on? New master cylinder kit and new Goodridge hose fitted.
Will take the clutch and gear box a part later this week, after the stiffness eases up.
Andy.
29th June 2009
Posts: 146 Sportster/Buell Model: Ironhead Sportster/Buell Year: 1974
Damn, Sounds like you have a bad brake caliper.
29th June 2009
Posts: 1,267 Sportster/Buell Model: xlx Sportster/Buell Year: 1985 Sportster/Buell Model #2: XLCH Sportster/Buell Year #2: 1979 Other Motorcycle Model: Sprint ss Other Motorcycle Year: 1967
The caiper got ya.When they sit the piston will corrode(makeing a spot so piston won't return all the way). Rebuild the caliper (cleaning piston real good). Use dot 5 only.
Sorry to hear you were tossed. I have had my break stick too. Ended up changing master,hose,caliper,fluid all new. The PO was nice enough to use dot3 3 and 5 don't mix.
29th June 2009
Posts: 790 Sportster/Buell Model: Ironhead 1000 Sportster/Buell Year: 1973
son of a b, glad your ok man.
Chris B. -'73 Ironhead
30th June 2009
Hi,
I am fine was stiff for a couple of days. There is a small hole in the MC that allows the fluid to return. I am going to check that sucker tomorrow to see if it is blocked.
Not looking forward to seeing what has happen with the gear box.
Andy.
30th June 2009
Posts: 4,104 Sportster/Buell Model: Ironhead XLH Sportster Sportster/Buell Year: 1978 Sportster/Buell Model #2: Ironhead XLT Sportster Sportster/Buell Year #2: 1977 Other Motorcycle Model: Honda CBX 1000 Other Motorcycle Year: 1979
Had a similar problem with my newly-acquired Honda CBX. Rebuilt both front calipers and the MC. On first ride, front brakes began to lock up. Fortunately, it was a gradual lockup and I was able to pull over with smoking brakes and relieve the front line pressure by cracking the lines. Turned out to be a very small bleed hole in the MC that was plugged with a tiny bit of junk preventing pressure from relieving in the lines/calipers. Once cleaned out, all is perfect again.
Eric
1st July 2009
Posts: 560 Sportster/Buell Model: xlh Sportster/Buell Year: 1980
WIth regards to the spill youare a lucky SOB. The mechanicals of the machine not so much.
29th June 2009
Banned
Posts: 3,923 Sportster/Buell Model: XLH/I.R.C. Special Sportster/Buell Year: 1974
You listed "New master cylinder kit" as one of the last things done...
...to the bike.
Do you mean that you re-built the m/c?
If so, go back and take a second (and third and fourth) look at what you did.
Most mechanical problems are owner-generated and looking back at the prior work done on a specific component will usually reveal this.
| Thread Tools |
| Display Modes |
Hybrid Mode
