22nd March 2012
Posts: 123 Sportster/Buell Model: Iron 883 Sportster/Buell Year: 2010
Alarm Indicator Light Comes on When going Downhill.
So everytime I go down a pretty steep grade the red security key light comes on, when I level back out it turns off. Just wondering if anyone knows what's going on with that. Even though my bike came stock with the alarm option it don't actually have one installed.
2010 Iron 883
22nd March 2012
Posts: 5,631 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
You need to check for diagnostic codes.
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
22nd March 2012
Turbo Mafia Test Pilot
Posts: 1,069 Sportster/Buell Model: XL1250NT LSR #1171 Sportster/Buell Year: 2007 Sportster/Buell Model #2: XL1200R Sportster/Buell Year #2: 2007
If the light comes on, you probably have the TSSM - Turn Signal Security Module. But, your symptom sounds like a wiring issue, probably something shorting out when the ass end is up. Maybe jack up the back end of the bike and see if it comes on? And yes, khaskins is right, pulling codes will give you a clue where to look.
Turbo Mafia Charter Member
Authorized Hellcat Customs Test Rider
I'm not crazy, I'm sanity challenged.
Please support my rookie Bonneville attempt!
http://www.gofundme.com/AsotinLandSpeedRacer
The Last Truly Amateur American Racing!
3rd April 2012
Posts: 116 Sportster/Buell Model: Iron 883 Sportster/Buell Year: 2009
Do you have it out of gear and just coasting down the hill? If so, stop doing that.
That is the only time my iron does that. My parents live on a mountain, and when I leave from there I like to just let the bike idle, out of gear while I coast down the dirt road to let the engine warm up a bit before I flog it all the way home. That's the only time that light comes on. Something to do with the bike moving and running, but not in gear. Must be a conflict between the speed sensor and the security module.
If I properly let it warm up in the driveway, and just keep it in second gear all the way down, it doesn't come on.
Do you have the black round key fob with your key? if so, you have the security system installed, just no siren. the siren was optional for that option....
4th April 2012
Ohm's Mafia
Posts: 4,729 Sportster/Buell Model: 1200N Sportster/Buell Year: 2007
Bingo!....and
Bingo!...well close.
Doesn't have anything to do with the bike being in gear. If the clutch lever is pulled in or the bike is in neutral and is traveling for over 60 seconds over 10mph you will get a code. Probably have a B1154 if you check your codes:
http://xlforum.net/vbportal/forums/s...ad.php?t=18260
Cosmo
4th April 2012
I'll be sure to check out the codes tomorrow when I get home from work. Have apprenticeship classes till 9:30 tonight
4th April 2012
Ohm's Mafia
Oh....and make sure you write them down before you clear the codes!
5th April 2012
Thanks Cosmo, I knew I was close
10th April 2012
B1154...
Yep that be what happened...thanks all!
| Thread Tools |
| Display Modes |
