Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle - Bottom End
famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27)
Figure Machine
Progressive Suspension
NHRS Performance
Biltwell
Old 13th April 2012
LORD-ORI's Avatar
LORD-ORI LORD-ORI is offline
Sportster/Buell Model: XL883 XL1200
Sportster/Buell Year: 0409
LORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the roughLORD-ORI is a jewel in the rough
Default XL883 2005 engine are they using aluminum for the buttom case? crack on the buttom
I just got XL883 engine at the buttom of it an oil leaking , so i checked up on it and there has been a weld job from previous owner... and i guess not good enough to keep the oil from leaking... so now i want to weld it, is the new sportster buttom case using an aluminum case or steel material?
Old 13th April 2012
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to beholdmaru is a splendid one to behold
It is Aluminum.
Old 13th April 2012
LORD-ORI's Avatar
heres the trouble
Old 13th April 2012
lil joe lil joe is offline
Sportster/Buell Model: xlh 883/1200
Sportster/Buell Model #2: xlh 1200
Sportster/Buell Year #2: 1988
lil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nicelil joe is just really nice
That does not look like welding to me. Looks like someone put some JB Weld or
some type of epoxy on there for a quick fix. If I'm seeing it right, it's on the seam where
the 2 halves of the cases meet.
Old 13th April 2012
BWP 5p's Avatar
BWP 5p BWP 5p is offline
JESTER Mafia-Hooligan Div
Sportster/Buell Model: 1200 R
BWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant futureBWP 5p has a brilliant future
Yep.....that's not weld. lil Joe is right........an attempt to patch....not fix is what THAT was/is.
Depending on how bad the crack/leak is.......I'd be more inclined to clean and degrease it thoroughly.....and try some silicone sealant!
Stuff: YES
Old 13th April 2012
aswracing's Avatar
A Million Facts & Figures
Sportster/Buell Year #2: 1999
aswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud ofaswracing has much to be proud of
I've had some success doing what BWP describes on crankcase half leaks, but let me add one step ... hook your mightyvac up to the breathers and pull some vacuum to pull the silicone into the leak.
Click Here to Contact Me
Old 13th April 2012
Rico 05R's Avatar
Rico 05R Rico 05R is offline
JESTER MAFIA
Sportster/Buell Model: NRHS 1250-R
Great tip Aaron, thanks for passing that one along.
A Member of The Cell
Old 13th April 2012
AustinXL's Avatar
AustinXL AustinXL is offline
Turbo Mafia Test Pilot
Other Motorcycle Model: FXDL
The "weld" job underneath looks like JB Weld....
Old 13th April 2012
Jimbos883's Avatar
Jimbos883 Jimbos883 is offline
Bike Builder
Sportster/Buell Model: 883/1212 XL Custom
Sportster/Buell Model #2: XLCH STROKER
Sportster/Buell Year #2: 1959
Jimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to allJimbos883 is a name known to all
You don't want to weld the cases at the seam, if you ever need to split the cases it will make it impossable.
Try the silicone
2004 Vivid Black 883 Custom, CONVERTED With NRHS 1212 Cylinders, 10.5 to 1 NRHS Dome Pistons, Stage 2 NRHS 1200 XB Heads, SE .551 Cams, TC88A, All the Right Stuff
