5th May 2012
Posts: 10 Sportster/Buell Model: Xl883l Sportster/Buell Year: 2007
So it's a conicidence. I had it running for 10-15 mins. I turned it off and now all I hear is the fuel injecton, no clicks, lights turn on, check engine diag is still clear.
5th May 2012
Ohm's Mafia
Posts: 4,723 Sportster/Buell Model: 1200N Sportster/Buell Year: 2007
You checked both ends of the battery cables to make sure everything was tight right?
The system relay and starter relay are the same. Swap those. If your starter relay was bad pay attention to hear if the fuel pump comes on to prime when you first go to start the bike. If the one relay was bad and you swapped it with the other relay....the fuel pump will not prime now. Although...sometimes just handling these things can get them to work for a little bit. Also, of course, see if it starts.
Also....while you are screwing around by the fuse block....pull all the fuses out (should have mentioned this before too) and clean off any corrosion on them. 07'-09' are poorly design and anytime the bike gets wet water runs down the fuse block....common issue for many electrical gremlins. Check to see if there is corrosion on the relays too. If there...best bet is to purchase new ones as that corrosion can bleed into the relay housing itself and cause issues.
Cosmo
6th May 2012
I got my new battery in the mail today. All the issues seem to be cured. It strange how a bad battery can have so many signs. Sorry the answer isnt more exciting, but it's nice to be back on the road.
6th May 2012
Ohm's Mafia
Nice!...thanks for letting us know what cured the problem.
7th June 2012
Update on the status. My bike worked a lot better after I replaced the battery, but it still had some issues starting cold, since this is my first HD I figured it was normal.
Last weekend I was unable to keep it running (she would die after about 5-10 seconds). My Mechanic told me that my fuel pump is out... Common problem with the 2007s but since mine only has 2k miles I didn't think that was the issue. So I'm out a bike fora couple of weeks until I can get the funds and order the parts. Anyone know a place online to get these cheaper?
Thx!
7th June 2012
Posts: 5,620 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
Sorry I meant crank position sensor.
The bike is all stock, never done any mods.
New premium gas about a week ago.
My bike is always in neutral when I start
Premium gas will cause carbon buildup. 883L is rated for 87 octane.
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
7th June 2012
Posts: 540 Sportster/Buell Model: XL1200N Org/Blk Sportster/Buell Year: 2007
Thx!
Before shelling out the bucks for a new pump, double check the relays if you haven't already and also read this.
TT328 – August 9, 2007 – 2007 XL Fuel Pressure
2007 XL Pressure Regulator / Low Fuel Pressure
With the help of the dealer network we were able to isolate some recent no start and poor drive quality complaints caused by inadequate fuel pressure. On some ’07 Sportster models the fuel pressure has been recorded well below the service
requirement of 55-62 PSI. This finding lead us to the conclusion the pressure was bleeding down past the large pressure regulator o-ring.
In order to ensure proper positioning and minimize movement of the o-ring a new service kit has been introduced. Use labor code 7164 and order part number 61005-07, which consists of a “Castle” Washer, Filter Screen, 1 Small and 1 Large O-Ring and is
intended for use on 75268-07/A/B Sportster fuel pumps. The “castle” spacer is installed with the openings pointing downward to prevent fuel flow restriction and should be only added to 75268-07B or earlier XL fuel pumps. Inspection processes were put in place prior to 2008 model launch, and in late August of 2007 XL production will be making a running change to a 75268-07C fuel pump. These fuel pumps will not require the “castle” spacer. The original regulator service kit (p/n 61015-04A) will remain available for situations requiring regulator replacement, service of a 75268-07C fuel pump or service of an already upgraded -07B and earlier pump.
Erbie
2007 Nightster Orange Pearl/Black
Nothing too special. Willie G Skull accents, V&H Slip-ons w/ "Quiet" baffles, SE A/C w K&N filter, FuelPak, flipped mirrors, adjustable road pegs, LePera Barebones.
7th June 2012
Thx Ernie- I have the later model...already checked.
| Thread Tools |
| Display Modes |
