The Sportster and Buell Motorcycle Forum Figure Machine
NRHS Performance Long 2
Get Lowered
Old 15th May 2012
tiderider's Avatar
tiderider tiderider is offline
USCG Mechanic Retired
Sportster/Buell Year: 1972
Sportster/Buell Year #2: 1969
Other Motorcycle Model: FXE Superglide
Other Motorcycle Year: 1976
tiderider will become famous soon enoughtiderider will become famous soon enoughtiderider will become famous soon enoughtiderider will become famous soon enoughtiderider will become famous soon enoughtiderider will become famous soon enough
Default Air filter cover and back plate
For the experts, will this work with a tillotson on a 69?
Harley Shovelhead air cleaner
The Beast of Burden 69 XLCH
Old 15th May 2012
72 Ironhead XLH's Avatar
Sportster/Buell Year: 72
should work just fine, adapting a backplate from a Bendix caeb will work too, just need to close off a vent hole.
Old 15th May 2012
tiderider's Avatar
Thank you sir, I thought it might.
Old 16th May 2012
DR DICK's Avatar
DR DICK DR DICK is offline
DR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to behold
the back plate is the tillotson unit.
the bendix back doesnt work correct. it lacks the notch for tilly choke lever clearance.
the cover may or may not work.
all bikes use the same cover EXCEPT 66-69 ch. those bike use a cover with a notch (apprx 3/4" deep 3" long) in the bottom edge to clear the mag.
i think that setup with the baffle is 71.
Old 16th May 2012
tiderider's Avatar
Thanks DR. I appreciate the info, if the price stays low then it may be worth a gamble.
