Biltwell
Zippers Performance
Biltwell
Figure Machine
Old 22nd June 2012
BigRodney BigRodney is offline
Sportster/Buell Model #2: Road King
BigRodney will become famous soon enoughBigRodney will become famous soon enoughBigRodney will become famous soon enoughBigRodney will become famous soon enoughBigRodney will become famous soon enoughBigRodney will become famous soon enough
Default Headlight and oil light question 1975
Well we got the bike running but the headlight and oil light don’t work. We started to remove the headlight and in the process it worked. Turns out that if you push it in it turns on, what I think is happening is that the ground connection on the back of the bulb itself is hitting the case of the flasher unit and creating a ground so I’m thinking it’s a grounding issue. What do you think, where’s this system grounded?
The oil light looks like it has a break in one of the wires insulation at the base of the plastic bulb holder and the wire doesn’t look too good but I didn’t take it out yet. Is that bulb replicable or do I need the whole plastic bulb holder thing?
Didn’t have time to trouble shoot this last night so that’s all I know at the moment. Thanks for the help.
The next person that uses the term “new normal” is getting a bitch slap.
Old 22nd June 2012
2007Low's Avatar
2007Low 2007Low is offline
Sportster/Buell Model: XL1200 Low/TTS/Gronked
Sportster/Buell Model #2: XLCH1000
Sportster/Buell Year #2: 1975
2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about2007Low has a spectacular aura about
If I remember correctly, the headlamp ground wire is riveted to the headlamp bucket. The plug is a three prong unit, one side of the plug should have two white wires in it, the other side should have the ground wire in it and the middle of the plug should have a yellow wire it in.
I don't think you can relamp the oil light, probably have to get the whole unit.
If your feet smell and your nose runs, you're upside down.
U.S.A.F. Veteran
Old 23rd June 2012
nikki's Avatar
nikki nikki is offline
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
the whole oil lamp unit need to be replaced as a unit . Nikki
the difficult can be done immediatey the impossible takes a little longer
Old 23rd June 2012
Looks like I can get the oil light from the dealership for $10. I’ll follow up on the headlight issue. Thanks.
