4th June 2012
Posts: 574 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2004
Planning a rebuild this winter
I have a few issues with my 2004 XL1200R and plan to iron them all out with a comprehensive rebuild in the coming winter. Frame needs powder coating, jiffy stand bushes are worn and mounting corroded, starter clutch needs replacing, tyres need replacing, I want to polish the fork stanchions and the triple tree, fork seals could do with changing, will need new rear pads by then, front brake lines got a caution at the annual test so need replacing etc. etc.
As I spent most of last years summer running season sorting out various problems one by one, had the exhaust off three times, spending a small fortune on gaskets in the process it seems sensible to do it all in one hit, particularly as I have decided I want to keep it. Yes I know as soon as it is back together I will buy a new one, but that is my problem.
So I have read the rebuild stories, seen pictures of many owners garages that would put my Indy to shame, but do not really have much idea of the true magnitude of the task. I am an experienced wrencher but not on Sportsters. How long does it take (hours) to get to a bare frame and would you suggest I remove the obvious major sub-assemblies (triple tree and forks, engine, etc.) so I have reference points on which to focus my work or go for a total tear down? I plan to replace all wear parts during the rebuild (rubber mounts, head bearings, swinging arm bearings, rebuild callipers any corroded/worn bolts etc.) is there anything else which should get my attention whilst it is disassembled? I do not plan to touch the engine, except for a new starter motor or clutch. Whilst on that subject any opinion on either replacing the starter clutch with a HD replacement part, an All Balls clutch, or All Balls or Twin Power replacement starter motor?
Any advice greatly appreciated.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
4th June 2012
Posts: 16 Sportster/Buell Model: 1200R Sportster/Buell Year: 2005
I would suggest some tackle boxes to store nuts and bolts. Use some tape or drop in pieces of paper to label the bins / compartments.
I'm in the middle of restoring my 72 Torino and I found that piece of advice to be priceless.
'05 1200R
5th June 2012
Posts: 357 Sportster/Buell Model: xl 1200 Sportster/Buell Year: 01 Sportster/Buell Model #2: xl Sportster/Buell Year #2: 74
If your'e powder coating the frame? You must tear down "all the way". about 4 hours, and lots of blue painters tape & a sharpie to i>d everything thats comes off. no biggie. Then tape off the bearing houseings everywhere before taking to the powdercoater. And if you don't have the manual, get it, cause you will forget something along the way. Have fun bo.
22nd June 2012
Posts: 7 Sportster/Buell Model: looking Sportster/Buell Year: any
Let the coater tape or plug everything. Mark what needs to be covered or protected and the coater will use heat resistant tape, plugs or covers. Cost of masking is usually included unless it is a big masking job.
22nd June 2012
Posts: 13,175 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
I put all the fasteners back in the parts where they belong.
I tape my parts with masking tape, take photos and give my power coater detailed written instructions and he does a perfect job not coating what I don't want coated.
26th June 2012
Thanks Guys, really useful info. When powder coating the frame do I mask off the VIN number plate and other HD markings which identify the bike? The areas around the various markings are in A1 condition so it would not impact on the overall appearance of the finished job.
| Thread Tools |
| Display Modes |
