The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 2
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Suspension, Frame, Forks, Handlebars, Fuel Tank, Oil Tank, Fenders
Ricor Shocks
Progressive Suspension
Primordial Cycles
Old 15th July 2012
maurino17's Avatar
maurino17 maurino17 is offline
maurino17 is an unknown quantity at this point
Default Fender compatibility?
Hey everyone,
I am starting to watch ebay for used fenders. I want to switch the orange front and rear fenders on my 2005 883r for black fenders.
What years can I buy that will be compatible? My bike is carb if that makes any difference.
Are all narrow glide front ends compatible, including dynas, and the nightster?
Are rears 2004 to present compatible for my 2005?
Thanks
PS I always wondered do all sportsters 2004 and later have the same frame and just different suspension and seats etc to make their ride different?
Old 15th July 2012
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: ZX6R
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Pretty much. But the rear fender can be tricky. 07-09 had a large cut out for the ECM to mount. Where as 10+ eliminated this as the ECM was mounted behind the rear cylinder. Keep this in mind when choosing a fender as the hole really dampens the look of some spring solo seats. The frames are the same, so I would imagine the mounts would be.
Surely, someone with definitive advice will chime in soon.
Old 15th July 2012
motorend's Avatar
Oh, and remember you kinda have to stay with nightsters and irons with the front fender. The 48's and superlows (midglides) run a different front fender as yours as well as any model with a 21" front tire. Basically just make sure the front is a narrow glide and a 19" tire for fender compatibility.
Old 15th July 2012
maurino17's Avatar
thanks motorend. . that was the only info I found when searching. . . is the ECM the computer?
I'll never be mounting a spring solo so that won't be an issue.
Where is the ECM on my 2005?
Old 15th July 2012
motorend's Avatar
Yeah the ECM is the computer for fuel injected models, 07+. I believe you have an ICM located under your rider seat. Can't give details on it as I don't have a carb model. But I would imagine you would be OK on switching the rear. Personally I would avoid 07-09 so you don't have that hole.
Give it time you will get other responses.
Old 15th July 2012
maurino17's Avatar
also meant to ask are all narrow glide front fenders from all bikes and years the same? They appear to be.
