16th July 2012
Posts: 1,213 Sportster/Buell Model: 1200 C Sportster/Buell Year: 09
Thanks folks, I would not run over 150 mi. anyway unless caught in a have to situation, I really like to have plenty of fuel...
Thanks and have a good one...Tater...
Sportster Owner/Rider since age 72...lol... Rider since Simplex...???
09-xl1200 "C" Vivid Black, Cast 19" Frt. Wh., Moded Stage 1, X14iEDs...
MicroTach +, Higher wider H-bars, Mustach bar Mtd. Hwy. pegs...
Viking Shock Cutout Saddlebags, Mustang Seat, Rear Mt. Signal Lt. Kit, SuperBrace...
16th July 2012
Posts: 238 Sportster/Buell Model: 883 Superlow Sportster/Buell Year: 2011
I usually run it to about 180 or about 50 miles after the light comes on.
16th July 2012
That's about what I'm thinking I coud do (50 mi.) in a need to case, I usually seem to have a very slight bit over a gal. left when the light comes on, if 4.5 is correct...
Thanks all, and have a good one...Tater...
16th July 2012
Posts: 898 Sportster/Buell Model: XL1200C Sportster/Buell Year: 2009 Sportster/Buell Model #2: XL1200L Sportster/Buell Year #2: 2009
Tater, my C will start to sputter at WFO after 180 miles. Actually pulled into station at 190 miles, still running & it took 4.2 gallons. Too close for me. I usually gas up at 150 to 160 these days.
Aklim, if you run it out of gas, the pump will continue to run untill you shut off the ignition, thereby burning the pump out. If you hit the kill switch when the bike stalls you'd be OK. I doubt it would set the residual gas in the tank on fire, but I don't care to test that theory.
Brian '09 1200C (black of course), 19" front wheel, det. windshield, Sundowner, mini apes, Big Sucker, x14IEDs, 12.5" Progressive 412's, Intiminators, Gronk mod
I didn't buy a Sportster 'cause I wanted a Harley... I got a Harley 'cause I wanted a SPORTSTER!!! He who gives up liberty for security, will have neither. Ben Franklin
16th July 2012
Posts: 92 Sportster/Buell Model: XL1200L Sportster/Buell Year: 2009
Well atleast I know it will hold atleast 4.2 gallons. The pump and expansion room has to take up some. I am imagining that they gave the total capacity without the pump and including the expansion. I wonder if the designer left out the words actual capacity in the manual so that we could have a discusion this long about it.
17th July 2012
an obsession handed down
Posts: 1,471 Sportster/Buell Model: 1200 C Sportster/Buell Year: 2005
I've thinking about putting a 1 gallon jug of gas on the rear and seeing how long she'll go with the lift...
Oh, and Brian...I thought 164 was pushing it. Geez!
Taxes are paid!
17th July 2012
That doesn't make sense at all. I have run a few cars out and the pump never runs after the engine dies. I can hear the pump prime when the run switch is set on. I pulled the plugs and the pump stops with the engine so it cannot be still pumping.
I believe there is a pump relay that will only be set to run when the engine is running or it is being primed. Otherwise, if you run out of fuel and leave the ignition on, BOOM!!!
And yes, the wife left the bike in run mode one night. Battery was low the next day but no explosion.
17th July 2012
GM only runs the pump while the engine is running. This is for accidents so that the pump is not putting fuel on the ground. Ford uses a switch in the passenger compartment that trips in a head on collision. I have not paid attention to the pump when stalled. I know the tilt kills it.
17th July 2012
The wife is convinced that soon she will be following me with 4.5 gallons of gas in the truck soon.
17th July 2012
I stalled it but the pump was silent unlike when it primes.
| Thread Tools |
| Display Modes |
