The Sportster and Buell Motorcycle Forum Licks Visormatic
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER & BUELL MOTORCYCLE RACING > Sportster Motorcycle Drag Racing
Tanjis Kahn, george (58), mwndragon (56), XxValDeexX (32), ELPYRO (31)
Figure Machine
The Dart Flyscreen
CV Performance
  #91
Old 24th July 2012
rocketmangb's Avatar
Jester Mafia
Other Motorcycle Model: 48
rocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant futurerocketmangb has a brilliant future
NO NO !
No Snake Oil !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1200C
Mikuni HSR 45
Jetted 30 slow,175 Main
97 Needle,Clip posistion 3
Daytona Twin Tec TC88A,Rico Nomad Map
Patriot Defender Pipe
Royal Purple 20W50 MC oil
Wix 57148 oil filter
Max Power, 77.73
Max Torque, 75.98
Old 24th July 2012
madnss's Avatar
madnss madnss is offline
Amateur Hour
Sportster/Buell Model: 883 Xl
madnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to behold
Ill try some redline !!!!!! Rocket
Old 24th July 2012
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really niceBob s hog is just really nice
red line makes a good product out there anymore when it comes to oil there all pritty good.
Old 14th August 2012
madnss's Avatar
Amateur Hour
Factory clutch is holding up after my tranny clutch issue. The weather has finally broke here in the Midwest, no more 100 degree days in the 10 day forecast. Going to head to the track Friday if time allows. If I go I have some nonpump gas fuel that I'm going to try. The rule of thumb for the fuel is to bumb up the main two jet sizes. Don't have time for a Dyno tune with the fuel so I'll just try 2 jet sizes bigger and go from there. If my mph does not hit 115mph or higher I'm assuming it will need more fuel or less. I believe that's how a person can tune a main jet without a Dyno on the track. Amy input would be helpful, thanks Ryan
Bob s hog's Avatar
what race fuel are you running 116 now keep in mind you are better off to give her more timing ,116 or most race gases are more dead then they are explosive like super at the pump will light easer then 116 race gas id leave your jets alone unless you are running alcohol then yes buy all means jet up but alcohol is hard on parts very corrosive .
madnss's Avatar
Amateur Hour
U4.4 vp gas. octane rating is around 102 or close to that. i don't have the compression for those other high octane fuels. this fuel is oxygenated.
Old 15th August 2012
mac93 mac93 is offline
Sportster/Buell Model: 1200
Sportster/Buell Year: 95
mac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nicemac93 is just really nice
We went from C12 to VP113 a couple years ago. Definitly had to jet up on both the main and t-jet just can't remember how much but 2-3 sounds about right. Not only picked up some power but it's also more consistent. Good luck.
madnss's Avatar
Amateur Hour
Thanks mac.
Jester Mafia
If you jet up and she wont ET or MPH you know shes fat
madnss's Avatar
Amateur Hour
Rite on! I'm hoping to break into the 11.40's
