The Sportster and Buell Motorcycle Forum Get Lowered
Flying Piston
Sportster Specialty
Lickscycles
Licks Holiday
Old 30th July 2012
73Sporte 73Sporte is offline
Sportster/Buell Year: 1973
73Sporte is an unknown quantity at this point
Default Runs Poor
Help I have a 73 xlh at steady speeds only it lugs like a miss.
and after 50 miles or so the rear spark plug won,t fire.
but if i pull the plug wire off about 1/2 inch it will fire.
New Coil ,Plug wires ,spark plug, points and condenser.
Replaced Points and condenser ingiton system witl Mallory E-Spark Ingition system.
Rebuilt Carb.Bendex Tryed all the jets for Carb.
Ck Compresion 120psi after 4 strokes.
Did cylinder leakage test .Rear cylinder Exhaust valve slight leak
Had valve job both heads. Still have same problem.
Any advice would be aperciated.
Thanks 73 sporte
Old 30th July 2012
nikki's Avatar
nikki nikki is online now
Sportster/Buell Year: 1982
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
Thanks 73 sporte
check the push rod adjustment , run a compression test with the bike fully warmed up like after a ride . Nikki
the difficult can be done immediatey the impossible takes a little longer
Old 30th July 2012
Monkeywrencher's Avatar
Monkeywrencher Monkeywrencher is offline
Sportster/Buell Model: XLSa
Sportster/Buell Year: 82
Sportster/Buell Model #2: FLHTC
Sportster/Buell Year #2: 1987
Monkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished roadMonkeywrencher is on a distinguished road
Sounds to me all the symptoms of running rich, then eventually fouling a plug.
Over jetted posibly. When I was still running my Bendix, my idle tube was flooding the engine. I couldnt do much with it so I converted to a CV. Look at your tube running verticle from the air cleaner side while its running. See if you see fuel dripping from around the top of this tube.
Old 30th July 2012
CaptCaveman's Avatar
CaptCaveman CaptCaveman is offline
Sportster/Buell Year: 1981
Other Motorcycle Model: Various
CaptCaveman is an unknown quantity at this point
I'll go with running rich. When you pull the plug is it a nice light tan or a sooty black?
Still crazy after all these years
Old 30th July 2012
ultra...good's Avatar
ultra...good ultra...good is offline
Sportster/Buell Year: 1974
Other Motorcycle Model: 1999 FLHTCUI
ultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to beholdultra...good is a splendid one to behold
Are you using compatible coil, wires, and plugs. Certain type of this, does not work with certain type of that.
Beyond that, and I would verify the ignition first, I had a similar problem and like already mentioned, the carb was way too rich.
Old 30th July 2012
85mm's Avatar
85mm 85mm is offline
Sportster/Buell Model: XLCH (mongrel)
Sportster/Buell Year: 1972
85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough85mm is a jewel in the rough
Mixtures that are too lean don't fire good.
50 miles is about one gallon of gas. Do you have an extra filter in the gas line? The tank level drops and not enough pressure to push gas through the extra filter. Take the filter out of the line.
Or, possibly clogged gas tank vent. Next time it happens, just twist the cap open enough to let air in.
You could ruin your electronic ignition pulling that wire off the plug.
BBRRAPPPP-snick-BRRAAAPPPP-snick-BBRRAAAPPPPP-snick-BBRAAAPPPPPP...
Old 1st August 2012
Thanks for the suggestions I will check the out .And let you know.
Thanks 73sporte
