The Sportster and Buell Motorcycle Forum
Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
XLF Gallery XLF Classifieds XLF Blogs XLF Chat XLF Shout XLF Arcade XLF Disclaimer/Privacy Statement/Terms Of Use
Sportster Motorcycle Motor - Top End Discuss Sportster Motorcycle Top End issues. Rockerboxes, Valves, Cylinders, Pistons, Rings, Lift Rods, etc...
Don's Cycleware
Mini Stats
Members 33,901 Entries 0
Members Entries
Threads 111,261 Reviews 19
Threads Reviews
Posts 1,415,560 Polls 702
Posts Polls
Content 223 Files 29
Content Files
Links 95 Ads 0
Links Ads
Supporting Vendors
BikerKiss.com
Thread Tools Display Modes
Old 2 Weeks Ago
Likemlouder's Avatar
fisherofmen
Sportster/Buell Model: 883 XL
Sportster/Buell Year: 97
Sportster/Buell Model #2: WIDEGLIDE
Sportster/Buell Year #2: 07
Likemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of lightLikemlouder is a glorious beacon of light
Originally Posted by CharlieB View Post
You can clean the carbon out without removing the heads.... the water-mist injection trick works to do that really well. Get the engine hot, remove the air cleaner, start the engine. Lock the throttle at about 1200rpm, and use a fine mist spray of plain water into the carbs throat. Dont squirt in water. Make a mist in front of the intake and let it be sucked into the carb. Do that for maybe 5 minutes. If you want - put a floor fan on a crate and blow some air onto your engine while you do this - but its not absolutely needed.
The water will turn to steam and clean the carbon out of the head, piston, cylinder ridge, valves and seats. This trick has been known at least since WWII when mechanics noted the pristine innards of fighter engines that had battle boost (water injection) to get a few extra HP from their motors. It works.
great trick and it will work very efficientlly when done as described. but if you squirt in water as a solid. then you will have a problem. i have stopped carbon knock in older cars this way for years.
if you are not confused you just don"t understand the situation
LIFE IS SHORT PRAY HARD!!!!!
she's just an old lump of coal. but she will be a diamond someday. not quite as lumpy. but not quite a diamond yet.
always a work in progress!!!!!!!!!!!!!
Old 2 Weeks Ago
Hot Rod Sporty's Avatar
Hot Rod Sporty Hot Rod Sporty is offline
NOT "REALLY NICE" ANYMORE
Hot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to allHot Rod Sporty is a name known to all
My understanding is that the '04 and up heads are a higher flow head. I think you'd be better off cleaning up what you've got rather than go for a lower flowing head in the earlier model heads.
Read this with the understanding that I am NOT an expert on heads. Hopefully Dan from NRHS will chime in soon. If not, I'd suggest PM'ing him before spending money on the '02 heads.
________________________________________
RIP James "Mr. Jimi" Melton - 1947-2008
Godspeed brother.
"Dream as if you'll live forever. Live as if you'll die today." --James Dean
"A narcissist is someone better looking than you are." --Gore Vidal
"I just love the 'mechanicalness' of it"
--Indian Larry Desmedt
Old 2 Weeks Ago
aswracing's Avatar
Sportster/Buell Model: XL883
Sportster/Buell Year #2: 1999
aswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the roughaswracing is a jewel in the rough
That's only true of the 1200 heads. Rubber mount 883 heads are the same as the pre-rubber mounts when it comes to the chamber and ports and valve diameters.
Old 2 Weeks Ago
Remy13's Avatar
Remy13 Remy13 is offline
Sportster/Buell Model: 883L 1200 conversion
Remy13 is an unknown quantity at this point
Thinkin about it it does make sense, I always wondered how the water injection worked on the old planes, I guess it just helps cool the air and maybe provide some more compression in the engine. I'll keep that trick in minde hopefully it'll come in handy. for now I've already taken the heads off and removed 95% of it by hand
Web XLFORUM.NET
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XL Forum
