Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Motor / Engine > Sportster Motorcycle Motor - Top End
Sportster Motorcycle Motor - Top End Discuss Sportster Motorcycle Top End issues. Rockerboxes, Valves, Cylinders, Pistons, Rings, Lift Rods, etc...
Old 9th June 2010
Rebel Jon's Avatar
Rebel Jon Rebel Jon is offline
Other Motorcycle Model: ZX-9R Ninja
Other Motorcycle Year: 1995
Rebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really niceRebel Jon is just really nice
Default Head Gasket Replacement on 07 1200
All,
Thought I would share my experience of replacing a head gasket on my scoot. I had a fun 4 days (yes, 4 days) and learned a lot about Harley top ends.
First, a disclaimer: I am not a certified mechanic. My processes are not the end-all only way to do anything. I know just enough to be dangerous. Don't take anything I say as "Gospel", but rather just one person's experience in trying to save some money by doing work himself. If you're not comfortable or competent enough to attempt this or any task envolving disassembly of any motorcycle, DO NOT DO IT.
Now on to the goodies:
I noticed a small oil leak coming from the rear of the number two (rear) cylinder between the jug and the head. I had a bad head gasket. I went to the dealership and got the gaskets (head gasket, 2 breather o-rings, rocker box gasket, upper pushrod cover o-rings, and 2 rocker box cover gaskets). It cost me around $40 for the complete set. The service tech at the dealership said that I had to replace the cylinder gasket (between the jug and engine housing). I was unsure about that, since I wasn't removing the jug. I will get back to that point here shortly.
I started by removing the seat and tank, which is really easy on a fuel-injected bike. The fuel fitting from the fuel pump is similar to that on an air chuck, so it basically just pops off. The number two cylinder (on my bike) has a temperature sensor in the center of the head that has a wire coming out of it, so I disconnected that from the molex plug just infront of the oil tank. I then removed the rocker box cover and rocker box.
Note: Be sure to follow the Harley Service Manual when you remove the rocker box. The manual says to remove the large screws last and in small increments and in a cross pattern. This is important because when you loosen these bolts, you are draining the pushrods and lifters of oil and you don't want to warp anything or create another problem somewhere else.
Once the rocker box is off you only have the 4 head bolts holding the whole mess on. Disconnect and remove the spark plug.
Remember when the service tech told me to replace the lower cylinder gasket? I found out why. The 4 head bolts actually hold both the head to the jug, but also the jug to the engine casing. If you are VERY careful and don't move the jug around much and don't disturb the cylinder gasket, YOU SHOULDN'T HAVE TO REPLACE THE LOWER GASKET. I choose not to replace that gakset, even though I was told to. You make your own decision if/when the time comes.
I cleaned up the top of the jug where the head gasket goes and this is what it looked like:
You can see the oil residue on the right side of the jug where I had the oil leak. You can also see 4 head studs and 2 breathers.
And then took a pic of the inside of the cylinder looking at the top of the piston:
After I took a straight razor and cleaned both the upper of the jug and the lower of the head (the two mating surfaces of the head gasket) I replaced the head gasket and 2 breather o-rings. The manual says to put the o-rings UNDER the head gasket, BTW. Replaced the 4 head bolts and torqued to spec.
VERY IMPORTANT PART COMING UP, DON'T TAKE A BATHROOM BREAK RIGHT NOW!!
The head bolt torquing process is a little involved. You have to torque to an initial spec, in inch-pounds. Then a secondary sepc, in foot-pounds. Oh, and in a crossing pattern to spread the force over the gasket evenly.
Once that process is complete, back off each of the 4 head bolts in 1/4 turn increments in a cross pattern. Don't cheat, you'll regret it later.
Now it's time to bolt the head down for good.
Hand tighten the 4 head bolts. In a criss-cross pattern, torque to initial spec, in inch-pounds. Again, in the same criss-cross pattern, torque to final spec, in foot-pounds. Finally, in the same criss-cross pattern, add an additional 85-95 degrees of sweep (another 1/4 turn) to each bolt. The manual was very specific about this process, so it's one from which I didn't deviate.
Once the head is torqued down, replace the rocker box gasket and reinstall the rocker box. Follow the Harley specs for bolt order and torque specs.
New rocker cover gaskets (two in my case) and reinstall the rocker box cover.
Don't forget to reinstall the spark plug, and temperature sensor from the rear cylinder.
Here's where my 4-hour job turned into a 4 day job.
When you removed the rocker box from the head, you lost all oil pressure in the pushrods that pump oil into the head to lubricate the rockers. I was told that the lack of oil would result in valvetrain chatter once the bike was started again. I was also ensured that the chatter would go away once oil pressure was re-established in the pushrods and lubrication was back in the rockers. I let the bike idle for 5 minutes, and the chatter persisted.
I let every word that my mom didn't like me saying fly as my bike was, at that point, a big, shiny paperweight.
My dad saved me when he suggested that we prime the lifters and pushrods before starting the bike.
We primed the lifters by forcing oil into the engine casing through the return line in the oil cooler that I installed over winter. We took engine oil from the oil tank and forced it into the line from the cooler back to the engine with a large plastic syringe. This forced oil into the lifters and pushrods and primed the rockers before the bike was started. We only forced about 500cc of oil into the case. Once that was completed, and the lines to the oil cooler were reinstalled, I fired it up, and she purred like a kitten.
I reinstalled the seat and rode her away.
If any part of this is unclear or if I seem to have skipped a step, it probably is or I probably did. Ask me questions. That's why I wrote this up--to spread the knowledge. I've learned a lot from this forum, this is just my small part to pay it foward.
I need to thank the usual people for their help in the entire process:
K3VL4R, you've proven, yet again, that there is little you can't/won't try on a motorcycle. Thanks for all your help.
My brother Jake was a big help in getting everything apart-small hands.
My buddy Jake let me borrow the coolest torque wrench on the planet. A Snap-On electronic torque qrench that vibrates when you get near the input torque, and beeps when you are there. Then it displays the actual torque that was put on the bolt. Pretty sweet. Now he just needs to buy a bike for himself...
Finally my dad and his girlfriend. It was in her garage that this whole mess took place, and it was his suggestion that got my bike back to life.
Sportsters are like prison shanks;small, deadly, and fast. --K3VL4R
Old 10th June 2010
Bobo's Avatar
Bobo Bobo is offline
Sportster/Buell Model #2: X1
Sportster/Buell Year #2: 1999
Bobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura aboutBobo has a spectacular aura about
Somethings I do is use Cometic gaskets because often after I get it together I have to take it apart again
I also use assembly lube on anything that I take out and put back in. When the lifters come out I let them sit in oil.
And before I button up the rocker covers I squirt oil everywhere and down the pushrod tubes.
Old 11th June 2010
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Interesting that your head gaskets required the use of o-rings. I was under the impression that the new version of the head gaskets (the only ones you can buy now) require NOT using the o-rings. (scratching my head trying to remember where I read that)
I only use the after market MLS Cometic gaskets that don't accept the o-rings. I can assure you with no doubt, using o-rings with gaskets that aren't designed for them will fail.
Interesting that the lifters didn't quiet down right away. I've had my bike torn down more times then I care to count and never encountered that. But, I'll keep your trick in mind when it happens in the future. (notice I don't doubt it will happen AND that I will have my bike torn apart again )
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 14th June 2010
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
That's me exactly! Put it together.....dis-assemble...put it together....and I also slather stuff with oil. I installed new lifters last summer and let them soak in oil overnight. They pumped right up.
PS: Nice write up Rebel Jon
Stuff: YES
Old 15th June 2010
CharlieB's Avatar
CharlieB CharlieB is offline
Sportster/Buell Model #2: XLH 883 Deluxe - sold now
Sportster/Buell Year #2: 1986
Other Motorcycle Model: FXDWGi
CharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really niceCharlieB is just really nice
Originally Posted by Rebel Jon View Post
All,
The service tech at the dealership said that I had to replace the cylinder gasket (between the jug and engine housing). I was unsure about that, since I wasn't removing the jug....Once the rocker box is off you only have the 4 head bolts holding the whole mess on. If you are VERY careful and don't move the jug around much and don't disturb the cylinder gasket, YOU SHOULDN'T HAVE TO REPLACE THE LOWER GASKET.
Its really pretty hard _not_ to move the cylinder. If you move it at all, you run a pretty good risk of gasket failure, if not immediately, then down the road in the not too distant tomorrow.
I like all you said - but - really - if you got it down that far, replacing the base gasket is about 10 percent more work, pulling the jug, cleaning the bottom, cleaning the case, new gasket, and reseat the jug. With the right tools you can pull the wrist pin, leave the piston in place _or_ pull the jug off the piston and compress the rings on the way back together. When you _do_ pull the jug, it makes the cleaning it much easier.
Old 23rd January 2015
pcontiman's Avatar
pcontiman pcontiman is offline
pcontiman has disabled reputation
Default BWP Nice bike.
BWP - nice bike!
Thanks for the writeup on this procedure. I need to do mine and a highly recommended shop here in SD quoted me $580 for both cylinders down to the case. An excellent price but for the price of a gasket kit I'm planning on giving it a shot myself.
by the way, Citywide Cycles in San Diego comes highly recommended by the local speedbike shop (They don't work on Harleys). Give Matt a shout if you need some work done.
www.bible-research.org
mikeLI_77's Avatar
mikeLI_77 mikeLI_77 is online now
Sportster/Buell Model: XL1250c
mikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond reputemikeLI_77 has a reputation beyond repute
Nice work. I have never seen anyone leave the intake and exhaust on the bike while doing this. Is that how your service manual says to do it. I am going to have to look at mine again now. Did that cause any problems with trying to reinstall the head and line up the intake and exhaust while not trying to disturb the base gasket at all?
2002 XL1200C (originally)
Hammer 1250 kit W/ 30° reverse dome pistons, billet 2.25" crush forward offset open air cleaner, billet intake manifold, Impact 560's, Sledge Hammer pushrods, Buell XB heads with crush level head porting, Mikuni HSR 45, 177.5 main, 25 slow, Clip 4th slot from top, Jim's powerglide II lifters,
Supertrapp supermeg exhaust 20 disks and open end cap, S&S roller rockers, Alto Carbonite clutch with Energy One 15% heavier spring plate, Daytona twin tech single fire ignition 1005s
Ricor intimnators, 13" Ricor IAS shocks, Brembo dual disk setup from a 2012 street glide with matching brembo street glide master cylinder,
Koso T&T multi function speedo/tach
States I Have rode through
BWP 5p's Avatar
Originally Posted by pcontiman View Post
BWP - nice bike!
Thank You Sir. I appreciate the compliment!
As far as the tear down........I recommend pulling the intake and the exhaust completely to get them out of the way. I also pulled my Cylinders clear off (NOTE: always stuff rags under the pistons as you pull them to avoid debris getting in the crankcase.
AnaChris's Avatar
AnaChris AnaChris is offline
Sportster/Buell Model: 883xlc/1250
Other Motorcycle Model: FLHRCI
AnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant future
question: is it normal to replace only the failed gasket...if it were me I would have dont the whole top end. is that overkill? idk enquiring minds wanna know
2004 883C/1250, 30degree reverse dome 10.5:1, matching crushed XB1200 heads ported w/oversized valves, S&S roller rockers, Hammer .600 cams, billit intake, hsr42, TC88, innovative afr, bronze oil gear, alto carbonite clutch, patriot defender, all balls starter, 1 1/2 tank lift, f6 key relocation,steering damper
Old 24th January 2015
BWP 5p's Avatar
Personally........I would do both, AND the base gaskets as well! My base gaskets @ 20,000 miles were a real job to get off the jugs! Lots of scraping with a razor blade! Probably should have soaked them overnight in something to soften them up!
