11th June 2012
Posts: 102 Sportster/Buell Model: 1200s Sportster/Buell Year: 96
Question for NRHS
Hi Guys!
I bought a 1250 kit about three years ago from y'all (stage II XB heads). I have been gearing up to get her dyno'd in the near future but confronted with $750 bucks to do it, I am scratching my head. At it stands, the bike is bringing me big smiles and tons of joy, and when I twist it up with my biker buds, I generally leave them behind me. The bike has an updated but still stock ignition (screaming eagle module, replacement module in the nose cone). So, what exactly am I leaving on the table by not getting a programmable ignition, and having it dyno'd? Is it not worth the trouble? Might a stock setup be getting me %90 the way there or am I in all likelihood leaving lots of efficiency on the table? Or, might you recommend getting a programmable setup and not bothering with dyno?
For what its worth, three years out. . .the bike runs great! Doesn't seem to burn any oil and just yesterday I was riding with a bud; he was on his Triumph 900. We wicked it on and I saw him in my rearview mirror. When we stopped next, he asked, "So is it just the cubic inches that lets you do that?" I chuckled and we talked about it for a bit. Thanks for the smiles guys. . . . . . .
Best,
josh
11th June 2012
Posts: 10,217 Sportster/Buell Model: 07 883 X2 plus 5 Buells Sportster/Buell Year: 2007 Sportster/Buell Model #2: 92 Sportster/Buell Year #2: 96 Other Motorcycle Model: and 2 more!!
$750 for a dyno tune?? Where are you located as that is a ridiculous price for a carbed bike.
Dan
NRHS
303-702-1600
www.nrhsperformance.com
The truth is out there. It's only a matter of time!
11th June 2012
JESTER MAFIA
Posts: 9,130 Sportster/Buell Model: NRHS 1250-R Sportster/Buell Year: 2005
Originally Posted by newHDnut
...I have been gearing up to get her dyno'd in the near future but confronted with $750 bucks to do it, I am scratching my head...
A Member of The Cell
11th June 2012
Posts: 1,197 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XR-1000 Sportster/Buell Year #2: 1984
not that expensive
A good dyno tune is not cheap but, not $750 dollars.  A price more like $300-400 is about right for a through (ie: carburetor adjustments, changing jets, adjusting timing ect) dyno tune. About 2-4 hours of labor at the average shop rates. ($50-75 hr)
Jesse
2002 XL1200S "The Black Beauty" NRHS 1250 kit CI, NRHS Stage 1 TS heads dual plugged, NRHS Hurricane Air Filter, SE 536 cams, Rich Products Thunder header, 42 Mikuni, Daytona Twin Tec ignition w/ Dyna coils. 97.4 HP, 85.5 Torque 1984 XR-1000 S&S Crank/rods w/windage tray, Vision Grinding Cylinders, Arias 11:1 compression pistons, Andrews XR-1000-1 cams, Baisley modified dual plugged heads, Rich Products Thunder header, 38mm Delortos, Daytona Twin Tec ignition w/ Dyna coils. (the never ending project but, got a 66 Barracuda drag car sucking up all the funds and time)
11th June 2012
Posts: 13,143 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
As Dan asked, what part of the planet do you live on?
11th June 2012
Posts: 1,737 Sportster/Buell Model: 1200S Sportster/Buell Year: 2002 Sportster/Buell Model #2: XLH883 Sportster/Buell Year #2: 2003 Other Motorcycle Model: Triumph Bonneville Other Motorcycle Year: 2012
As much as I like to tinker, your bike sounds in the category of "leave well enough alone, son!"
11th June 2012
Posts: 436 Sportster/Buell Model: Iron Sportster/Buell Year: 2009
If you are pleased with the way it runs, you are getting decent fuel milage, no pinging or deceleration popping, and the spark plugs are not really white or very black and wet i would say all is good let it be. especially for $750 .
2009 Iron 1250 Kit Stage 2 Light 883 Heads 497 Cams RB LSR 2 into 1 Thundermax Ecm
11th June 2012
Posts: 292 Sportster/Buell Model: XLH NRHS 1250 Sportster/Buell Year: 1995
I have a 95 conversion with dyna 2000p ignition. There are 4 maps programed into it. I live in LA & got it dyno tuned for $150, $225 if they have to change jets...$750 id pretty ridiculous.
11th June 2012
Oh my...sorry. 750 would include the cost of buying a programmable ignition. They want $300-$350 for the dyno....(still seems high to me). The shop was recommended elsewhere on the site. The bike has an S&S G, the kit, and stock everything else. I live in Brooklyn ny and the shop recommended for the dyno is on Long Island.
Thanks for the support/input.
J
11th June 2012
what kind of ignition? Since yours is a 1996 all you need is a simple Dyna plug in box style ignition which I sell for $204. You can still use your stock coil even.
I would look for another dyno tuner if it was me.
Dan
NRHS
