14th June 2012
Posts: 2,358 Sportster/Buell Model: XL 883 C Sportster/Buell Year: 2005 Sportster/Buell Model #2: 2007 XL 883 Sportster/Buell Year #2: 2007
anyone used one of these batteries?
just curious
The only regret about the sporty, is that I didn't buy it sooner.
14th June 2012
Posts: 5,669 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
After having problems with 2 oem batteries in 5 years, I went back to HD batteries.
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
14th June 2012
I was just curious...I don't know what the stock dimesions are...
does our bike (2005 and 2007) take
YTX14ahl or YTX14L
14th June 2012
Posts: 913 Sportster/Buell Model: Sportster Sport XL1200S Sportster/Buell Year: 1998 Sportster/Buell Model #2: Fatboy 1450 FLSTFI Sportster/Buell Year #2: 2002 Other Motorcycle Model: Kawasaki KDX125sr Other Motorcycle Year: 1991
YTX14ahl or YTX14L
I thought the battery number for a 04-11 was YTX14L-BS (yuasa's battery number)
The size of the YTX14L-BS from yuasa is L-150mm x H-145mm x W-87mm (-/+ 2mm)
Terminal layout: Left = NEGETIVE & Right = POSITIVE + (With the terminals on the edge nearest to you)
1998 XL1200S - Harley 2-1 fitted with V&H SS2R, SE race ignition (7500rpm) with matched SE coil, SE yellow leads, NGK Iridium spark plugs, NRHS HurricaneFlow 3" centre hamcan filter, usual 'S' engine internals (w-grind cams, flat top pistons & 10:1 higher comp twin plug heads), SE heavier clutch spring. Soon to have SE 42mm hsr mikuni carb..
14th June 2012
Posts: 574 Sportster/Buell Model: XL1200R Sportster/Buell Year: 2004
+1 Yuasa YTX14L-BS. Note the ‘L’ designation is required so that the terminals are the correct way around. YTX14-BS is the same battery and cheaper but will not fit. Mine was installed 18 months ago, I use a battery tender during the winter and so far 100% performance with instantaneous starts.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
