Ironworks Magazine
Licks Holiday
NRHS Performance Long 2
Old 22nd June 2012
Hammer's Avatar
Hammer Hammer is offline
Sportster/Buell Model: Sportster XLH 1200
Other Motorcycle Model: Heritage Springer
Other Motorcycle Year: 2002
Hammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really niceHammer is just really nice
Default Running Bad
Hello everyone!
I have discussed this bike before, it's a 2001 1200XLH If I take the bike on say a 15 mile trip and stop. After restarting the bike it seems to spit and sputter and cough real bad. The last time when I thought I found the problem I had a vacuum line leaking going to the petcock. The carb has been rebuilt and jetted to the best of my ability. It's almost like when the bike gets hot it really acts up. The first time some one said about battery leads or flooding. Or possibly air intake leaks. Any ideas befor I take it to the Stealer ship, because at this point I am just scratching my head.
Benny
Old 22nd June 2012
Bigrick110's Avatar
Bigrick110 Bigrick110 is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 04
Bigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really niceBigrick110 is just really nice
Do u pull choke to restart.? Do u pump throttle on restart?
I'm 5'8" 165 and my names not Rick! Go figure!
Old 22nd June 2012
Hammer's Avatar
Yes I do pull the choke to restart. give just a little gas
Old 22nd June 2012
Bigrick110's Avatar
I had problem with choke not seating if bike was even slightly warm. Could cold start with no problem by pulling choke, starting, no throttle, within 10 seconds push choke in, then use throttle lock to let engine warm. Fun right? On restarts one twist of throttle no choke and it would start no problem. If I tried choke r twisted throttle more than once, I would have fuel everywhere. Changed entire choke assembly and no problem since. Maybe when pulling choke ur flooding it cause it's not seating back properly. Hope this helps.
Old 23rd June 2012
Hammer's Avatar
You might be onto something. I have been spoiled with my other bikes that have injection. I have been thinking hard about getting the S&S super E carb kit. Any suggestions or dislikes about this.
Old 23rd June 2012
Bigrick110's Avatar
I'm running cv 40 jetted, I see a lot of guys running Mikuni HSR42, in dyno section. I'm running 94 hp, Cf STD so that puts me about 90 hp SAE. Have had no other issues with cv besides choke. Check out intake and exhaust thread.
Old 29th June 2012
Hammer's Avatar
Well I think maybe (just maybe) I have finally found my problem. FYI= I took my bike for a ride the other day and the same old thing. Runs good then started popping & coughing and then ran good again. Then it just shut off. Finally got it restarted by moving the wires around on the coil. But It was also low on gas. I got the bike home and put gas in it and decided to take a closer look at the coil and in doing so found the the wire was broke in one of the rubber connectors. repaired it and took it for a ride, and not one cough or miss. I sure hope this is it because this is the best this bike has ever run.
Old 29th June 2012
jharback's Avatar
jharback jharback is online now
Other Motorcycle Year: 1998
A good reminder that the old saying, "Most carb problems are electrical problems." still holds true.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
Old 29th June 2012
Hammer's Avatar
This one had me baffled. I have always been fairly good at rebuilding and tuning carbs. But this thing just gave me a fit with the electrical problem. I lost a lot of confidence in my carb skills until I found the electrical problem.
Thanks again everyone for the help!!!
Old 1st July 2012
USMCDevilDogg's Avatar
USMCDevilDogg USMCDevilDogg is offline
USMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really niceUSMCDevilDogg is just really nice
I've having similar problems...I will look into the electrics tomorrow. Thanx for the help.
