Get Lowered
Sportster Specialty
Get Lowered
  #51
Old 22nd June 2012
professir's Avatar
professir professir is offline
Sportster/Buell Model: xl1200c 105th Anniversary
professir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really niceprofessir is just really nice
I wondered about the speed as well, my rev limiter kicks in about 40mph in 1st.
Old 22nd June 2012
Gone Gone is offline
Yea I have a tach on my power vision tuner. As you can see I've never raced much. And RPM's makes me nervous.
Old 22nd June 2012
milmat1's Avatar
milmat1 milmat1 is online now
Known Troublemaker !
Sportster/Buell Year: 06
milmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant futuremilmat1 has a brilliant future
A Note on Shifting, You want to shift at a point where you will be back at the bottom of the torque curve, Too high and you Bog, Too Low and you'll Bog.. It takes practice...
My bike is still pulling like a train when it hits the rev limiter so unless I watch the tach I will hit the limiter everytime....
New to the Harley World, Some Good Info Here : NEW TO HARLEY'S
READING SPARK PLUGS: READING PLUGS
Check For Intake/Exhaust Leaks: CHECKING For Leaks
How to Check the Diaphragm! : Diaphragm_Test
REPLACING INTAKE/CARB SEALS:Replacing Intake Seals
MAINTENANCE INFO 04-06 : HANDY REFFERENCE
My futile attempt at Blogging: http://toolstolivewith.blogspot.com/
Old 22nd June 2012
SomewhatLost SomewhatLost is offline
Sportster/Buell Model: 883 hugger/1125R
Sportster/Buell Year: 1/8
Sportster/Buell Model #2: XLH 900 maybe...
Sportster/Buell Year #2: 1968
SomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really niceSomewhatLost is just really nice
don't fear the RPM's... they want to be your friend...
next time you are in a no-stress situation on your sporty, open it up a bit and let your sporty play in the +4K RPM's range... it will thank you for it...
actually if you had a solid mount evo, you would be able to see much easier/clearer just how happy those upper RPM's make it...
NOTE: As one wise professional something once stated, I am ignorant & childish, with a mindset comparable to 9/11 troofers and wackjob conspiracy theorists. so don't take anything I say as advice...
Old 22nd June 2012
SuperTed's Avatar
SuperTed SuperTed is offline
Other Motorcycle Model: Fairlane 500
Other Motorcycle Year: 1964
SuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to allSuperTed is a name known to all
Who needs a rev limiter anyway? Just one more un-needed thing to idiot-proof a Harley.
Please insert here:
- Poor attempt at cleverness/humor
- One too many quotes
- Oversized pic of my ride & lengthy list of upgrades
Old 22nd June 2012
madnss's Avatar
madnss madnss is offline
Amateur Hour
Sportster/Buell Model: 883 Xl
madnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to beholdmadnss is a splendid one to behold
I need a Rev limiter when I run my pump gas street sporty at the drag track.
Old 22nd June 2012
madnss's Avatar
Amateur Hour
Hold your throttle wide open, don't let off, fan your clutch as fast ad possible. Do that to redline, or wherever your bike runs out of power.
Old 22nd June 2012
I need a rev limiter too... at least in first, if I don't crank the throttle open fast enough I will get to my 7K rev limit somewhere around 1/2 throttle... actually it is usually a bit of a race to see if I can get to WOT before I start bouncing off the rev limiter...
Old 22nd June 2012
madnss's Avatar
Amateur Hour
I like to have it when I'm not at the track too. When the majority of time is spent over 5grand when riding, I hit it once in awhile
Old 22nd June 2012
also, just a a general, but mostly useless FWIW type thing...
from about 1957 to about 2001 (or to 2003 if you don't count the vrod) (and definitely not counting Buells...)
the fastest stock HD in the 1/4 mile for any given year was usually (always?) a sporty... if my foggy memory serves, generally by a good bit... like a 1/2 second or so faster then the next fastest model (usually the lightest Dyna?)...
so, you shouldn't be too surprised if your sporty at least keeps up... sporty's are pretty fast for girl's bikes
