22nd June 2012
Posts: 146 Sportster/Buell Model: sportster xlh Sportster/Buell Year: 1969
Made a seat, then messed it up
22nd June 2012
Posts: 46 Sportster/Buell Model: XLCH "correct for era" HA Sportster/Buell Year: '62 Other Motorcycle Model: G80 matchless Other Motorcycle Year: 60
Down the tubes?
Didja put springs down the frame tubes?
22nd June 2012
Yeah, there's springs in the tubes, I just need some with more compression.
Art
22nd June 2012
Posts: 1,644 Sportster/Buell Model: xlh Sportster/Buell Year: 1982 Other Motorcycle Model: FX Other Motorcycle Year: 1976
That looks waaay better than my first attempt. It can take a couple tries to learn a new skill. Keep on keepin' on...
When yer going around corners and the vinyl wants to bunch up and fold over, you can trap the folded triangular part under a pop rivet so it doesn't hang down. I usually cut out the excess inside the fold so it's only two layers of vinyl instead of three layers. I hope you can follow my description.
A little more shaping and rounding of the foam at the nose of the seat would make it look sleeker.
I got Chevy valve springs for free at an auto repair shop that work pretty damned well and would fit in those sockets perfectly.
1st July 2012
Second try making a seat
I think its looking better, I wanted to hide the seat mounts on the frame so I came up with this. Still have to get better tucking the material around the corners. I'm going to try another one.
Art
1st July 2012
Posts: 681 Sportster/Buell Model: XL Sportster/Buell Year: 1957 Sportster/Buell Model #2: XLS Sportster/Buell Year #2: 1979 Other Motorcycle Model: Indian Scout 741 Other Motorcycle Year: 1941
Hti the corners witha hair dryer or heat gun and some of the wrinkles will come out. Be careful tho! I do this with all my seats, both car and bikes. Great job regardless. Is this your first time doing a seat?
1st July 2012
Doesn't look too bad though.
If you are like me though it will drive you nuts until it is perfect to you
1st July 2012
I'll give the heat gun a try, this is actually my third try at making a seat.
Art
1st July 2012
Art
Man, pretty dang good for a third time! Upholstery is not an easy thing to do. There is a reason most folks buy theirs. It’s more work to do it yourself but great satisfaction when you’re done, and it’s your way too!
2nd July 2012
Posts: 273 Sportster/Buell Model: XLH883 Sportster/Buell Year: 1987
Looks good! Would like to see a pic of the pivot bracket if you could post it.
Also, for those interested in using leather, a good cheap source for leather is the thrift store or resale shops! Get an old leather jacket for cheap in the color you want and cut it up! KD
"If your horse kicks me, I'll shoot the son of a bitch!"
