swanny, Mrs Jimi, SnarleyHarley (63), UtahMark, ihjonny (56), fatchuk (55), provision (47), randreb (47), joeyhunter (44), junk runner jr (38), Pegscraper05 (35), cowboy_hamilton1@yahoo.co (34), wi1dwood (34) |
16th July 2012
Posts: 13 Sportster/Buell Model: custom Sportster/Buell Year: 03
How much Hp?
I have a 03 1200c and I was thinking about buying from nrhs the stock xb heads cams and use my old cylinders combo. How much horse power do you think this will make I will be running he stock carb with screaming eagle air filter and v&h long shots(for now anyways) and I have the dyna ignition Thanks
16th July 2012
Amateur Hour
Posts: 2,904 Sportster/Buell Model: 883 Xl Sportster/Buell Year: 1992
70 to 80 HP
16th July 2012
Amateur Hour
With your pipes you have probably 75 range. Good luck
16th July 2012
Would I be better off having my heads ported or going with stock xb?
16th July 2012
A Million Facts & Figures
Posts: 5,871 Sportster/Buell Model: XL883 Sportster/Buell Year: 2007 Sportster/Buell Model #2: Buell Cyclone Sportster/Buell Year #2: 1999
Your stock heads have some problems that are difficult & not particularly cost effective for a head porter to fix. Read about them here and pay particular attention to the chambers and the pictures of the ports from the chamber side. So while we could make them capable of supporting a lot more power, a person has to question whether or not it's worthwhile to pour that much money into a casting that's got some inherent design limitations.
Honestly, we could make a much better set of heads out of a pair of 883 heads of any vintage. Read this thread, for example, to see what we're doing with 883 heads now; 100hp is certainly within range when HAMMER Dan prepares a set. You could pick up a pair of those fairly cheap.
But also think about cosmetics; your cylinders are black with highlighted fins, right? What will silver heads, i.e. most XB and 883 heads, look like over those cyls? Is that acceptable to you? Or you could go straight black from an 883R or later XB, and then try to highlight the fins manually.
The 2004-2006 XL1200 head is, from a performance point of view, equivalent to the XB head, and they're black with highlighted fins which would match your cyls. They're also harder to come by and more expensive.
Either the XB or late model XL1200 heads are available from HAMMER PERFORMANCE here.
If you end up porting your heads, keep in mind that the head work that you used to be able to get from either NRHS or HAMMER is now available only from HAMMER PERFORMANCE. Read here for more information about this CNC process which has been under development and refinement for almost a decade now, has had thousands of sets of XL heads run through it, and has put more XL's over 100hp than anyone else out there. Also keep in mind that NRHS has not yet updated their web site, so all the dyno sheets and head pictures they show reflect work that's now only available from HAMMER PERFORMANCE.
16th July 2012
Thanks for the help I'm probably going to wait until the end of riddin season and give both hammer and nrhs a call
16th July 2012
Posts: 10,184 Sportster/Buell Model: 07 883 X2 plus 5 Buells Sportster/Buell Year: 2007 Sportster/Buell Model #2: 92 Sportster/Buell Year #2: 96 Other Motorcycle Model: and 2 more!!
The package you are proposing I too would say about 70-80 hp
Looking forward to trying to earn your business when you are ready
thanks
Dan
NRHS
303-702-1600
www.nrhsperformance.com
The truth is out there. It's only a matter of time!
16th July 2012
Posts: 13,143 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
[Quote from ReddTigger] "Air cleaners are not created equal. Recently I tuned a bike with a Screaming Eagle air cleaner got a baseline and then switched to the NRHS Hurricane Air filter, and retuned. The only physical change was with the AIR FILTER and picked up 6hp and 7lbs ft tq." [This was on an 883!]
IMO closer to 70hp. Power is limited by the things that limit it. Every component counts!!!!
Pick a shop, supplier or "expert" and do what they tell you. BUT keep doing your research, like you're doing here.
I have a 2007 1200 with a Hurricane AC, Supertrapp 2:1 and a PCIII running a drop in map, a full Dyno tune would get me more power.
Here's my sheet:
17th July 2012
Amateur Hour
I pulled 82 hp and 76 tq on a solid mount with thunderstorm heads pistons and 497 cams if that helps. the bike had a good 2 into 1 pipe. the bike made 74 74 with 1 3/4 drag pipes. I also had the stock carb and a screamin chicken air filter
17th July 2012
Thanks everyone, what would be considered a good 2 into 1 without breaking the bank?
