Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Era Specific and Model Specific > Frame Mount EVO Sportster Talk (1986-2003 models)
The Dart Flyscreen
CV Performance
Ricor Shocks
Speedway Instruments
redi2ride's Avatar
redi2ride redi2ride is offline
Sportster/Buell Model: Sportster 1200cc
redi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud of
Default wobble during hard cornering
I have experiance a sort of walking/wobble motion during hard cornering. It "seems" to be more in the left turns than the right turns. But not by much. What are the fixes if any?
"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." -- Benjamin Franklin
motorend's Avatar
motorend motorend is offline
Senior Master Bike Builder
Sportster/Buell Model: XL1200N (Sold)
Other Motorcycle Model: ZX6R
motorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud ofmotorend has much to be proud of
Mine was due to air pressure. Bumped my front tire to 36psi instead of the recommended 30 and the wobble was gone.
Motorhead52's Avatar
Motorhead52 Motorhead52 is offline
Sportster/Buell Model: 883 sportster
Other Motorcycle Model: BMW
Other Motorcycle Year: 1973
Motorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura aboutMotorhead52 has a spectacular aura about
yep weight of bike and 160 lb rider was good at 30 psi
I use 35 front 40 rear
denguy denguy is offline
Sportster/Buell Model: 1200
denguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enoughdenguy will become famous soon enough
Could you expand on what you meant by "hard cornering"?
knut knut is offline
knut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to allknut is a name known to all
Tire wear and profile, head bearings, wheel bearings, swingarm, tire pressure, fork springs/oil, shocks, triple tree, alignment...
veteransforpeace.org
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
I'm thinkin asphalt rather than sand?
Seriously, I would definitely try air pressure first, but then next would be fork oil and rear shock adjustment. I like to run over a good pothole and feel front to back to get the hit even.
If the front is stiff and the back is soft I adjust the rear stiffness until it's a good thump/thump, and so far that has always worked out good for me on all my bikes (at least the ones with so little adjustment as these). Cartridges require more adjustment, but the feel front to back still needs to be somewhat equal.
You may also get some good help from John's 7 pages of suspension sticky.
Mine is lowered to 11" shocks in the rear, so hard cornering is not much of an option unless I'm in dirt, and personally I don't see any use in trying to make a 30's era scooter into much more than it is. I figure there are limitations to speed that I reach long before the suspension is in full play.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
Rico 05R's Avatar
Rico 05R Rico 05R is online now
JESTER MAFIA
Sportster/Buell Model: NRHS 1250-R
Out of curiosity, what tires are you running?
A Member of The Cell
Old 17th July 2012
redi2ride's Avatar
20mph corner . I take it at 50-60 mph,scraping boot and peg.usually coming out around 45mphish. Just havin a lil fun.
Old 17th July 2012
redi2ride's Avatar
Shinko 777 , brand new. it did it with the avons and dunlops also.
Old 17th July 2012
motorend's Avatar
Again mine was the air pressure. I found it would get worse as I accelerated hard through the curve to the point of having to back off the throttle because of the head shake.
