The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 3
Get Lowered
Foxcreek Leather
wagoneer12's Avatar
wagoneer12 wagoneer12 is offline
Location: NE Wisconsin, someday I'll move back to the United States.
Sportster/Buell Model: Sportster 883C
Sportster/Buell Model #2: Chopped XLH
Sportster/Buell Year #2: 1967
Other Motorcycle Model: chopped XLH
wagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the roughwagoneer12 is a jewel in the rough
... and ensure that each pipe has 4 slits at the header end not just two; and use a pop can shim between the clamp and the header to improve the effectiveness of the clamp; and use a little Permatex Ultra Copper inside the pipe before sliding it onto the head.
Yep Mick, that'll do it. I would have gone that far if it didn't go away after the first try. BTW....these pipes have three slits and look original. Never heard of that or seen it before. usually 2, sometimes 4, but never 3.
doodah man's Avatar
doodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of lightdoodah man is a glorious beacon of light
Originally Posted by trappnman View Post
thought I was right, but went and checked some new springs- when new, springs do NOT have any spaces between the coils
that's weird, my last two sets of new springs did. they were not huge gaps, mind you, but just enough that you could tell. at any rate, the point is that the springs must be under a bit of tension at rest or the weights will flop around at idle and cause poor/erratic running.
steal your face right off your head!
Bob F's Avatar
Bob F Bob F is offline
Welcome to the XLForum.
Old 20th July 2012
800screws 800screws is offline
Sportster/Buell Year: 1971
800screws is an unknown quantity at this point
ok... did the points/timing and pushrod adj....runs way better....on the road it seems to run broken up when riding open throttle....
when sitting, it idles, and closed to about 1/3 runs clean, then it runs like crap when u open it the rest of the way...
could the 72 main be causing this? im going to try the 68 anyway...not gonna hurt.
Old 20th July 2012
doodah man's Avatar
would you say it sounds like it's spitting/sneezing back into the carb, or is it more like it stumbling/blubbering? if stumbling your dumping in more fuel than the bike can burn, and a smaller jet is in order - like you've already planned for. i think the 68 will do you good.
Old 20th July 2012
yup..thats exactly whats its doing....
now the main jet is that big hex jet? everywhere i look the main jet is pictured as a little flathead screw...i thought that was the main air leak jet?
am i missing something?
