16th July 2012
Posts: 50 Sportster/Buell Model: 883 XLow Sportster/Buell Year: 2009
93, 89 and maybe 87 octane?
Hi All,
My motorcycle is supposed to have high test, or 93 octane.
I put 89 in it and althought the note of the exhaust has changed- it still runs like a top.
I have heard that running 87 octane is a no go, any thoughts?
Thanks
Wayne
"It is better to be seen, then viewed."
16th July 2012
Posts: 5,631 Sportster/Buell Model: Sportster 883L Sportster/Buell Year: 2006 Other Motorcycle Model: Honda CB350 Cafe Style Other Motorcycle Year: 1970
Originally Posted by wayneo1
Hi All,
Thanks
Wayne
2009 883L (Not sure) 87 octane is suggested in the service manual for 2006 883L
2006 883L
AN Big Sucker Stage 1
Rejetted Carb: Slow 45, Main 175
Vance & Hines Side Shots
Flat Track bars, 4" Joker Machine Risers
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Lepera Daytona Sport or Lepera Bare Bones Solo
Black Progressive 412 12.5" shocks
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Ol' Greasy Karl of the Spirit Stalkers MC
Outlaw Name Generator
XLForum Business Card Template
BEFORE YOU CLIMB ON YOUR MOTORCYCLE, CHECK THAT THE NUT THAT CONNECTS THE HANDLEBAR TO THE SEAT IS NEITHER TOO TIGHT NOR TOO LOOSE.
16th July 2012
Posts: 15,415 Sportster/Buell Model: XLH 1200 Sportster/Buell Year: 1993 Other Motorcycle Model: Moto Guzzi California EV Other Motorcycle Year: 1998
Look in your Service Manual and go with what is recommended. If the engine is pinging then go to a higher octane. Otherwise, stay with what is recommended for your bike.
Jim in Italy
'93 1200
58mm Inverted Wide Glide Front End
WetDreamz Pipes
Six Piston Jaybrake Calipers
16" Carlini Apes
16th July 2012
Posts: 79 Sportster/Buell Model: XL1200C Sportster/Buell Year: 04
Prior to 2007 (carb'd bikes) Harley recommended 87 octane for the 883 and 91+ octane for the 1200.
Starting with the EFI bikes in 07, Harley changed the recommended octane for all Sporties to 91+.
Since the compression ratio wasn't changed on the 883, it's quite likely that you can still run a lower octane, especially when the weather is cooler.
04 1200C - Bub Jug Huggers - NRHS Hurricane Flow A/C - Daytona TC88A Ignition
16th July 2012
Posts: 13,156 Sportster/Buell Model: XL50 0596 Black Sportster/Buell Year: 2007 Other Motorcycle Model: E-Glide Other Motorcycle Year: 2003
I run 89 without any problems in my 2007.
16th July 2012
Red Beard Cycles
Posts: 9,824 Sportster/Buell Model: XLH-1208 Sportster/Buell Year: 1997 Other Motorcycle Year: ALL
HD tech will only consider 91 octane or better. Eventhough you manual may state otherwise.
To me, its cheap insurance.. Plus I get better mpg with at least 91
I AM THE REAL BAT-MAN!
You Can't Fix STUPID !
Originator of the " NIGHT LITE"
"Guess what?! I got a fever, and the only prescription... is more cowbell!"
"Horsepower Never Lies" - 'Speed's Performance Plus'
MY GALLERY
States I've Ridden in
71.3 hp 70.8 tq
1208cc 11.09:1 (Wiseco 10° Dome 10.5:1 .010 over) ,Screamin Eagle Dual Plug Heads (10° 61cc), Original SE A/C, Vance & Hines Straight Shots w/ Custom Baffles. SE 6800 ign,Dual BREMBO brakes/ Pirelli Night Dragon MU85-16 Rear - 100/90-19 Front. Progressive Springs & 412 HD 13½" Chrome Shocks, 5½" pullback riser w/ "reddtigger mount", Stebel Nautilus Compact Air horn, Kuryakyn LED tail light, Mustang Vintage Super Wide Touring Seat Chrome Tach mount w/ Stainless Tach.
Dragstrip King of the Satan's Barbers MC
Get your own 1%er name
17th July 2012
Posts: 14 Sportster/Buell Model: 883 Iron Sportster/Buell Year: 2010
I've been running 93 oct, it's an extra 20-25cents per fill-up then 91 octane.
I've seen what happens when you don't run the right octane way too many times in cars that I wouldn't try anything less then 91 in a newer sporty.
17th July 2012
If you think higher octane is better gasoline then you really should do a little more research. Higher octane is not "better" gas, it is "different" gas. Higher Octance gas just requires more effort to ignite. That's why it is recommended for higher compression engines. It does not pre-ignite.
It is not "better" gasoline!
17th July 2012
Posts: 253 Sportster/Buell Model: XL883N Sportster/Buell Year: 2010
Precicely. And not only that, running fuel with an octane rating higher than the engine and more specifically the ignition was designed for can lead to carbon build up. Higher octane fuels burn more slowly, so if the rating is too high, combustion isn't as clean as it could be. I use 87 myself, and I only ping in really hot weather in heavy traffic if I lug the motor. I've considered mid grade, but the ping I experience is infrequent enough not to bother me.
17th July 2012
I didn't say it was a better gas. I have seen 50-60 engines need valve jobs and even a few slugs replaced because people used 87 when it said to use 91+. Vw's, Ford's, Chevy's, Honda's. 4-8 cylinders. The pinging is worse for an engine then the little bit of carbon build up.
That's just my opinion based on what I have seen and cars that I have had to fix, so I won't risk it on my own motorcycle.
