Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > GENERAL AREA > Motorcycle Camping
Motorcycle Camping When, What, and When
cbsportster (67), sjeccles (50), 2011_Nightster (50), reeb (47), Maff (47), jl_rotary (40), UMLsilva (32)
Old 18th July 2012
sportsterpaul sportsterpaul is online now
Peter: My small "Wolfman" Beta bag that I run on the stock rack carries spare parts, service manual, shaving kit, tent sleeping pad, sleeping bag with room to spare. tank bag carries rain gear,(yeah, someday I'll have some of that nice "Stich" stuff), extra glasses, small amount of gear and visor/windscreen cleaner. Another small bag straps on top of the beata with extra clothing. If you're coming across check out Greg's homemade platform.
Old 18th July 2012
Phaedrus's Avatar
Phaedrus Phaedrus is offline
Couple thoughts on the Higgy platform, I assume it's aluminum, thickness?
Any thoughts on going bigger/ wider with it?
Old 18th July 2012
Screw Loose Dan's Avatar
I think I like Sportsters
Sportster/Buell Year #2: 2016
Over in Brad's thread on the topic, he mentions 3/16" thickness for the aluminum. I was thinking mine was 1/4", but it's been a long time, so it's probably 3/16".
The issue with going wider, it depends on your saddlebags (if equipped). The width of mine gets in the way as it is. No saddle bags? Probably not an issue to go a bit wider. And I wouldn't want to make it much longer. Depending on how you distribute the weight, it hangs off the back enough, IMO.
Screw Loose Dan
Current fleet:
2007 - 1200R (Orange bike)
2012 - XR1200X (XR)
Old 18th July 2012
Deacon Dan Deacon Dan is offline
Deacon Dan is an unknown quantity at this point
Be careful of too much weight to far back giving you the wooblys.
Only the first good shot counts!
Old 20th July 2012
Phaedrus's Avatar
I ordered 3/16 alum textured plate, a little softer than the 6061 and probably easier to drill.
I went a couple of inches wider my bags are soft, and worst case are quick detach.
Old 21st July 2012
Sounds good Pete! Let us know how you make out. I drilled the aluminium with one of those step bits and it wasn't all that bad. Even thicker aluminium like that is still pretty easy to work with. I used some bed liner to try to coat mine...which really hasn't worked all that well as much of it is flaking off.
Phaedrus's Avatar
Default Got the plate drilled and finished
I ordered the rack from HD should be here on tuesday
I drilled the holes in a a little different pattern
Gcram399's Avatar
Gcram399 Gcram399 is offline
I drilled the holes in a a little different pattern.
You can't go wrong with aluminum diamond plate. It's going to look good and work even better.
Support the forum because the
George
"Peace is that brief glorious moment in history when everybody stands around reloading . "
--Thomas Jefferson
Hammer Performance 1250 kit w/ 30* Reverse Dome Pistons, Smash Level 883 Heads w/ 1.770 Intake/ 1.615 Exhaust & PAC Alloy Beehive Spring Pack, Impact 560 Lift Cams, Hammer Billet Aluminum Intake Manifold, Air Hammer Naked Billet Air Cleaner w/ 3" K&N Element, Mikuni HSR 42, Dynatek 2000P Ignition, Energy One Clutch w/ 15% Diaphram, Muller Power Clutch, Basanni Road Rage 2-1 Exhaust w/ 4" Performance Machine Billet Tip. Drag Specialties 8-Bolt Encapsulated Rotor, Cycle Electric Regulator and Stator.
PistolPete PistolPete is offline
PistolPete is an unknown quantity at this point
ScrewLoose, how did you attach those two side cases to the bike (the pelicans, not the saddlebags)? is there some extra brackets under there?
2009 1200N - currently parked 7000 miles away
Paralegal Pete - Looking good! Honestly, I've never used all the holes in mine, but it's easy/cheap to drill them. Are you bolting this to you current rack or getting the solo rack like Brad and I have?
Pistol Pete - The side case pelicans are attached with EasyBrackets, so they mount/unmount very quickly and easily.
