NedNimrod, jduffy01, LVBOATDOC (61), glef (56), Dogsbd (51), darkcustom (36), jon8641 (29)
Fix My Hog
Speedway Instruments
Zippers Performance
Old 21st May 2007
Dakin Engineering Dakin Engineering is offline
Senior Master Bike Builder
Sportster/Buell Year: 1987
Sportster/Buell Model #2: XLH
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Sportster XLH
Other Motorcycle Year: 1995
Dakin Engineering has disabled reputation
Default '67 engine oil puddle
Seems to be coming out the primary at the kicker shaft? How does it get from the oil tank to the primary anyway?
I've never worked on a IH before, so forgive my ignorance, please.
Sam
Old 21st May 2007
fdny37's Avatar
fdny37 fdny37 is offline
Senior Bike Builder
Sportster/Buell Model: 93 Cubic Inch XLH
Sportster/Buell Year #2: 1968
Other Motorcycle Model: Softail Deluxe
Other Motorcycle Year: 2007
fdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nicefdny37 is just really nice
Dakin, are you saying the shaft is leaking from the seal were it comes out of the case on the right side of the engine?
Old 21st May 2007
BuckIRyder BuckIRyder is offline
Other Motorcycle Model: Heritage Softail
BuckIRyder has disabled reputation
My '72 has leaked there forever. Tried all kinds of things, new bushings ,various o-rings, etc. and it still drips. I wonder if its casting porosity. Anyway the oil that's dripping is from your primary/trans not from your oil tank. The primary is a separate inventory of oil from your engine. There is some potential for oil transfer between engine and primary but if every thing is in good shape there should be vitrually none.
Old 21st May 2007
ironhead7544 ironhead7544 is offline
ironhead7544 has disabled reputation
Check your primary oil level. Might be too high.
Old 21st May 2007
The oil goes in the oil tank and out on the ground. The trail comes from the primary in the vicinity of the kicker shaft. There is a check ball in the oil pump, right? Maybe it's leaking past there, into the crankcase and the crank bearing into the primary?
Cut to the chase; I don't want to pull the motor and find a welding job.
Sam
Old 22nd May 2007
72 Ironhead XLH's Avatar
72 Ironhead XLH 72 Ironhead XLH is offline
Sportster/Buell Year: 72
72 Ironhead XLH has disabled reputation
trying to find out if you mean the primary oil or the engine oil.
could be a loose/damaged hose,cracked tank.primary oil is not involved with engine oil.
Old 22nd May 2007
What year bike are we talking about?
Old 22nd May 2007
Sam,
Your oil tank may be leaking. Only way I know to check is to pull it and leak check. Engine oil goes from the tank to the pump. When the engine starts it unseats the ball check and oil flows thru the engine. If the ball check is leaking by it will collect in the cases and puke out the crankcase vent when you start. A leaking ball check won't give you the symptoms you see.
Old 30th July 2012
An old thread, but the same bike is back.
The constant drip was solved last year.
The "one-way" valve in the primary was stuck open.
Fixed with a self-tapping screw and a dab of JB weld.
Sam
