Go Back   The Sportster and Buell Motorcycle Forum > SPORTSTER MOTORCYCLE ZONE > Sportster Motorcycle Drivetrain > Sportster Motorcycle Transmission, Clutch, Primary & Secondary Drive
Speedway Instruments
NRHS Performance Long 2
Figure Machine
Get Lowered
View Poll Results: Have you broken a drive belt (secondary drive) on your Sportster Motorcycle
Yes 292 29.17%
No 709 70.83%
Voters: 1001. You may not vote on this poll
  #451
Old 30th July 2012
wedge's Avatar
wedge wedge is offline
Whitworth Products
wedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant futurewedge has a brilliant future
The broken belts I have seen always broke straight across and when they do that it's not possible for them to do anything except just drop out of the way in my opinion. I never heard of one shreading lengthwise, but that could be a problem if it does.
Whitworth Fork Brace: http://xlforum.net/vbportal/forums/m...outme&simple=1
Old 30th July 2012
nikki's Avatar
nikki nikki is offline
Sportster/Buell Model: xls roadster
nikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of lightnikki is a glorious beacon of light
A belt that shreds lengthwise is caused by the pulleys not running straight and true , when I put a Super Max belt drive kit on my 82 . Nikki
Old 30th July 2012
wedge's Avatar
Whitworth Products
You actually had one shred lengthwise? Did it flap where your leg would have been in the danger zone?
Old 30th July 2012
nikki's Avatar
No on legs being in the danger zone as I modified the stock chain guard and kept the little piece that attach's to the swing arm as the fibers shredded out the side . I recommend not choping the front pully cover and keeping the beltguard on to keep your leg safe. Nikki
Old 31st July 2012
wedge's Avatar
Whitworth Products
I guess my leg will be toasted if that ever happens, cuz I run no guards at all.
Old 31st July 2012
xrayrider xrayrider is offline
Sportster/Buell Model: 2003 1200C Sportster
xrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the roughxrayrider is a jewel in the rough
Saddlebags offer some protection if you have those.
Old 1st August 2012
wedge's Avatar
Whitworth Products
I have nothing extra on my bike at all. If it will still run and stop with parts removed, then parts get removed. Oh, that's a lie, I have a sissy bar and passenger pegs for the old lady. But if those weren't there, she would make sure it didn't run, so I guess it's not a lie after all...
Old 19th August 2012
morvenhouse's Avatar
morvenhouse morvenhouse is offline
morvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud ofmorvenhouse has much to be proud of
This winter I am going for a full strip down to powder coat the frame on my 04 XL1200R. Will also replace front and rear tyres at the same time, one item I need to consider is the tensioning of the rear drive belt? Any tips, at the moment I do not have the special tool as recommended by HD in their manual but may purchase it if there is not an XLF alternative method.
My patience and the Winter Rebuild are not well matched.
Coming soon:
2004 XL1200 R
Cylinder Head Work including:
1.900 intake 7MM 4.425 SG
1.615 Exhaust 7MM 4.651 SG
7MM Beehive Spring 600 Lift
Striker Performance 7MM Valve Spring Kit
HP 3563 30D76 3.563 30 Degree Piston with Reverse Dome, 76 CC Chamber
XL/ Buell 1250 kit, Black With Highlighted Fins
04/Buell XB Intake 10.676x.065x3/8 (-.050)
04/Buell XB Exhaust 10.730x.065x3/8 (-.050)
XL 560 lift Impact hammer Performance Cam Set
V & H Competition Series 2 into 1 Exhaust, 04-12 Xl models
Twin Tec Adjustable Ignition Module, 04-06 Sportster/Twin cam single 12 pin
1991 to Present Sportster (XL) - Energy One Extra Plate Clutch Kit
Old 20th August 2012
wedge's Avatar
Whitworth Products
After mine broke I started checking belt tension on every sporty I ran across, and most of them were looser than mine by quite a bit, so I loosened it. I am not using the factory spec, I have that 1/2" to 3/4" play, but with no tension on it (free play). I think this is less likely to stress the belt over time, but I need to see if this new belt goes past 40,000 miles (which is where the last one broke about).
BobWLR BobWLR is offline
BobWLR is an unknown quantity at this point
Buddy of mine got well over 100K miles on his FXR before he changed the belt. Claims everyone's belt is too tight. Even if the HD shop adjusts it.
