The Sportster and Buell Motorcycle Forum NRHS PERFORMANCE 2
Get Lowered
Licks Holiday
Sportster Specialty
Old 4th August 2012
DR DICK's Avatar
DR DICK DR DICK is offline
DR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to beholdDR DICK is a splendid one to behold
he probably did not work on the case in the photo?
ha.
thats the 84"teardown pic.
that work is over 25yrs old.
my welding skills have improved much since then.
Old 4th August 2012
sevenyears of famine's Avatar
sevenyears of famine sevenyears of famine is offline
Sportster/Buell Year: '60
Other Motorcycle Model: xs650
Other Motorcycle Year: '72
sevenyears of famine will become famous soon enoughsevenyears of famine will become famous soon enoughsevenyears of famine will become famous soon enoughsevenyears of famine will become famous soon enoughsevenyears of famine will become famous soon enoughsevenyears of famine will become famous soon enough
I ended up starting the notch with a cut off wheel, then flattening out with a file.
snapped in place
a 'lil boring action from last night
It feels pretty good snapping in place, it has to go on perfectly straight or it won't go. Here's a quick vid to show the fitment. Usually takes a bit to get off but I musta pulled just right here:
So, Dr. Dick. My first question, does it need to be tighter? Seems pretty snug. Or are you recommending tight "press fit" and no welding?
Old 4th August 2012
DirtyCory's Avatar
Sportster/Buell Year #2: 1972
DirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to allDirtyCory is a name known to all
nice job man!!
If your gonna do something, do it right!
Old 4th August 2012
JBGoode JBGoode is offline
Banned
Sportster/Buell Year: 1976
JBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud ofJBGoode has much to be proud of
Cool thread! One day I'll get to machining my own parts!
Old 4th August 2012
brucstoudt brucstoudt is online now
brucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura aboutbrucstoudt has a spectacular aura about
look's good,7yrsof. are you going to weld,or screw in place?
Old 4th August 2012
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
With some the lotetite stuff out there today you may could do that.
Murphy's Law
Old 4th August 2012
iNSaNeSHaNe's Avatar
iNSaNeSHaNe iNSaNeSHaNe is offline
Sportster/Buell Model: XLS roadster
iNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of lightiNSaNeSHaNe is a glorious beacon of light
LOOKS GOOD MAN if they fit real tight no prob. if very snug I'd clean both parts and then wipe the two mating surfaces with green permanent LocTite on another note when I did the blower cases I machined the inner and outer to an interference of .002 then put the case in my freezer for an hour when I took it out I heated the ring with my heat gun and dropped it right on and let it contract to the other case. good to see so many ppl involved in a great thread. let us know how it all works out I'm sure its better than before.
IF IT NEVER BREAKS THEN YOU DON'T RIDE IT
Old 5th August 2012
barefoot barefoot is offline
Sportster/Buell Model: XR 750
Sportster/Buell Model #2: RR 250
barefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the roughbarefoot is a jewel in the rough
Originally Posted by DR DICK View Post
if its tite back in the lathe, using some sand paper(120 grit) 'polish' the id bigger intill it does just slip on.
This is absolutely right, I do it all the time, not a chance in heck that a beginner could take out two tenths so it's the only practical way BUT be aware that you can lose a finger doing this. Regular sandpaper is probably safe but if you use emery cloth with the reinforced backing, it's stronger than your finger and can catch in the part.
Just be aware that when you stick your finger into something turning 800 rpm, be careful !
Old 5th August 2012
Hopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to all
Great work!
Not being critical but you said you were figuring out lathes as you went along so I will offer you a tip for what it's worth.
Always keep overhang to a minimum, in order to reduce tool chatter and get a better finish.
This includes the way you set up your boring bar and the parting tool so the tool sticks out just far enough to do the job and that's all. IE pull the parting blade and boring bar back into their holders as far as you can. And pull the holder back as far into the toolpost clamp as you can. You get less flex and vibration that way.
Also, keep overhang of the job out of the chuck to a minimum too. Cut your stock down to size first, then start drilling, boring turning etc, up as close to the chuck as you can. Surprising amount of flex in a long thin cylinder when machining the far end without a tailstock centre holding it in place.
And kerosene or WD40 can make a good lube when boring or parting aluminum.
Have fun with your lathe! I have been playing with them for years and am still learning.
(And PS, +1 on be cautious about sticking a finger into a rotating hole. Ok on a shallow large diameter hole if carefull, but for deeper, smaller holes, use a piece of wooden dowel with emery paper wrapped around it. A slot cut in the end holds the paper firmer.)
Old 5th August 2012
Thanks for the feedback guys. Bruce, I'm not sure yet but I'm leaning towards welding. Once it's done and closed up, I won't have to think about it or see it.
Thanks for the tips too Barefoot & Hopper. All good info. The only reason I've learned anything is because I have things that gotta be made -mostly aluminum spacers. It's forced me to dig up info and give it a shot. I really need to learn how to grind/sharpen my tools. I think I have a pdf of that southbend book, but I remember it being really long.
working with aluminum is forgiving, if it were steel I'd be burning up bits left and right
I'm thinking I could save a bundle if I whipped up my own loonynum trans gears
