famousperson (69), greanmeany1 (66), michael wait (58), Peter_nikols (49), Ace_Bruno (47), Buko (46), mike-munich, crackers (38), IrishThug (37), Stingray (35), 05low (27)
Sky Smith Insurance
Figure Machine
Old 5th August 2012
zipdog zipdog is offline
zipdog is on a distinguished roadzipdog is on a distinguished road
Default Clutch Help!
I finally got my '81 ready to ride today after 8 months of dicking around, but when I put it into first gear there is a odd "clink" sound, and the bike wants to roll ahead. It's impossible to get it back into neutral or any other gear while sitting still with the clutch lever pulled in. Clearly the clutch is not completely disengaging, Is this normal? It was not like this when I first got the bike with the original clutch. I have tried any number of adjustments, but nothing seems to help. I replaced the clutch discs and cable during the rebuild, so maybe this is contributing to the situation. Any thoughts or advice?
Old 5th August 2012
FearlessFrisbee's Avatar
FearlessFrisbee FearlessFrisbee is offline
Sportster/Buell Model: XL
Sportster/Buell Year: 1957
Other Motorcycle Model: Indian Scout 741
Other Motorcycle Year: 1941
FearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really niceFearlessFrisbee is just really nice
did you follow the sticky when adjusting the clutch?
http://xlforum.net/vbportal/forums/s...ad.php?t=70728
Old 5th August 2012
oldnavy's Avatar
oldnavy oldnavy is offline
Other Motorcycle Model: FXRS Low Rider
Other Motorcycle Year: 1986
oldnavy is on a distinguished roadoldnavy is on a distinguished roadoldnavy is on a distinguished road
If it's been sitting for 8 months go ahead and ride it a few miles as is and then readjust. I had a similar problem with my '72 which turned out to be something else, but sitting is bad for the clutch plates and disks to stick together. Riding around the neighborhood for a few miles will likely make some difference.
Old 5th August 2012
Vermonter's Avatar
Vermonter Vermonter is offline
Other Motorcycle Model: 80XS650/71CL175/7?gs550
Vermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of lightVermonter is a glorious beacon of light
I had this exact issue with my new clutch. Follow the sticky, and ride it around. It will be easier to shift while moving, and just be sure to hit neutral before you stop. After a few miles you will feel it loosen up.
"If a law is unjust, a man is not only right to disobey it, he is obligated to do so." Thomas Jefferson
Old 5th August 2012
Thanks for the info, guys. I'll ride it around some today and see if it loosens up some. I did follow the sticky to the letter, and the clutch was disassembled and out of the bike during those 8 months.
Old 5th August 2012
ezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of lightezmerf is a glorious beacon of light
Did you follow what the manufacture said to do to new disc b4 install?
Murphy's Law
Old 5th August 2012
I don't recall seeing any instructions...just the discs were there when I opened the box. They are Alto Red Eagle discs. I went to the Alto website, and there are no special instructions that I can find.
Old 5th August 2012
Are you using spacers and if so are they mushroomed.Are you using one spring are two?Myself I prefer the two springs but these also play a factor in the clutch.The springs can be tested.
What lube are you using put all this out here and I'm sure your get some comments.As far as plates go some need to be pre-soaked some steels need coating removed.I'm a barnett guy myself so I know nothing about Alto.Hope you luck
Old 6th August 2012
Hopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to allHopper is a name known to all
Running straight 50 oil or similar in the tranny? That can be some pretty sticky sh!t on plates.
If so, try some Harley Transmission Formula Plus. Works a treat.
Old 6th August 2012
ryder rick's Avatar
ryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really niceryder rick is just really nice
Do you have any of those leather covers on your grips or levers?
Covers or excessively large diameter grips may reduce lever travel.
Did you check your steels to verify they were flat when you replaced frictions?
Ryder Rick "If life doesn't kill me, nothing ever will."
