20th June 2012
Posts: 91 Sportster/Buell Model: XLH Sportster/Buell Year: 1974 Sportster/Buell Model #2: IH Sportster/Buell Year #2: 1981
Quick Question - RT / LT Side Shift
I know I could find the answer if I dug around but I've got a bet going. I was just asked which year the Sportsters went from right side shift to left. Specifically, what would you expect on a 1973 IH ? Thanks.
20th June 2012
Posts: 166 Sportster/Buell Model: sportster Sportster/Buell Year: 1976
74 would have been the last year for right shift as 75 and 76 had cross shaft,73 would be right shift.
20th June 2012
Posts: 3,171 Sportster/Buell Model: XLCH Sportster/Buell Year: 1962
20th June 2012
Posts: 2,237 Sportster/Buell Model: 1200s Sportster/Buell Year: 2001 Sportster/Buell Model #2: xlch Sportster/Buell Year #2: 1974
yep in hd tradition, never throw away anything. the cross shaft was a bad mistake but they had to get rid of un-used parts. i like the right shift especially in scramble. the shift was for the most part up and accessable so shifting was a snap in the curves unlike when the shift is just above ground level so you had better have the thing downshifted before hand. of course, depends upon the track, ours was counter-clockwise and turning to the left with only one right curve. i still love my 74 right shift but now, with the lefty sport, i got to watch what i am doing when i change machines.
20th June 2012
Originally Posted by GA_Ironhead
Thanks for that link - lots of good information there.
8th August 2012
Posts: 1 Sportster/Buell Model: Xlch Sportster/Buell Year: 1996
Is there a step by step and or a list of parts needed to make my 76 LH shift into a RH shift using parts from 74. Does anyone know of a company that sells such a conversion.
8th August 2012
Posts: 7,863 Sportster/Buell Model: XLCH 1000 Sportster/Buell Year: 1977 Sportster/Buell Model #2: 75 motor in Norton frame. Other Motorcycle Model: 42WLA 45, Harton, Narley Other Motorcycle Year: 1942
I think you would have to fit the earlier cam gearcase cover with the bushing in it for the RH shift shaft to pass through, and open up the tranny and fit the earlier shifter shaft that is long enough to stick out thruogh the gearcase and cover.
More dicking around than it is worth really.
In the tech stickies index in red near the top of the forum is an article on how to make the left foot shift linkage work much better than stock, might be easier.
8th August 2012
Posts: 487 Sportster/Buell Model: XR 750 Sportster/Buell Year: 1972 Sportster/Buell Model #2: RR 250 Sportster/Buell Year #2: 1976
Yeah, but while he's in there he could replace that wet clutch thing with the good dry clutch
8th August 2012
Posts: 2,464 Sportster/Buell Model: XLCH Sportster/Buell Year: 1975
come to the right side, my son! you'll never regret it...
steal your face right off your head!
8th August 2012
Posts: 705 Sportster/Buell Model: dragbike Sportster/Buell Year: 1960
They don't call it the "right" side for nothing....
